HELP!!! hard time starting
03-29-2012, 04:23 AM
The IGf signal is a confirmation from the Igniter to the ECU, that tells
the ECU that an ignition event has occured. If the ECU does not get the
IGf signal, it assumes that the engine is not running, and cuts fuel.
You need to check that you have no broken or shorted wires between
the Igniter and the ECU. Plugs have no bent or broken pins... no poor
connections.
Cheers... jondee86
Messages In This Thread
HELP!!! hard time starting - drift - 03-17-2012, 04:33 AM
[] - fax0815 - 03-17-2012, 09:18 PM
[] - drift - 03-18-2012, 07:16 AM
[] - fax0815 - 03-18-2012, 02:22 PM
[] - drift - 03-18-2012, 03:33 PM
[] - Ivan141 - 03-18-2012, 04:01 PM
[] - drift - 03-18-2012, 05:31 PM
[] - Ivan141 - 03-18-2012, 10:30 PM
[] - fax0815 - 03-19-2012, 12:59 AM
[] - drift - 03-19-2012, 01:28 AM
[] - drift - 03-20-2012, 07:58 PM
[] - Ivan141 - 03-20-2012, 11:08 PM
[] - jondee86 - 03-20-2012, 11:32 PM
[] - drift - 03-21-2012, 01:21 AM
[] - fax0815 - 03-21-2012, 01:49 AM
[] - drift - 03-21-2012, 02:38 AM
[] - fax0815 - 03-21-2012, 03:55 AM
[] - drift - 03-21-2012, 07:06 AM
[] - drift - 03-21-2012, 10:06 PM
[] - fax0815 - 03-21-2012, 10:38 PM
[] - drift - 03-22-2012, 01:32 AM
[] - drift - 03-22-2012, 02:56 AM
[] - drift - 03-23-2012, 10:10 AM
[] - fax0815 - 03-24-2012, 02:01 PM
[] - drift - 03-29-2012, 01:31 AM
[] - jondee86 - 03-29-2012 04:23 AM
[] - drift - 03-29-2012, 05:05 AM
[] - drift - 03-29-2012, 08:13 PM
[] - jondee86 - 03-29-2012, 08:59 PM
[] - drift - 03-29-2012, 09:12 PM
[] - fax0815 - 03-30-2012, 05:02 AM
[] - drift - 03-30-2012, 06:13 AM
[] - fax0815 - 03-30-2012, 11:51 PM
[] - drift - 04-11-2012, 09:01 AM
[] - fax0815 - 04-18-2012, 10:56 PM
[] - drift - 04-23-2012, 01:40 AM
  Coil charge time totta Crolla 0 583 01-23-2026 07:27 AM
Last Post: totta Crolla
  lntermittent starting totta Crolla 6 6,440 08-31-2021 06:21 PM
  Starting problems 4-AGE kouki Hanzo 3 4,788 08-31-2021 06:20 PM
  Hard start issue kazi 5 9,083 05-23-2017 11:31 PM
Last Post: kazi
  JDM trueno not starting. need help! kazi 8 12,150 03-12-2017 05:05 PM
Last Post: kazi
