HELP!!! hard time starting
03-30-2012, 05:02 AM
Post: #31
I thought you´ve already done a diagnosis
before we started with all the excessive investigation...
03-30-2012, 06:13 AM
Post: #32
Sorry but no. Remember, i got it to start so i didnt think i needed the diagnosis. Guess that shouldve been from point 1 huh. My bad on that one
03-30-2012, 11:51 PM
Post: #33
Fu** yeah, takes only minutes to do and saves all the hassle with radondom checking for broken stuff.
Saved you from buying a 2nd pair of injectors... Hope you get it sorted now. Easy as, on 4 AG(Z)E its either loose conectors or broken wires. Very uncommon for the actual electric part to fail. Check the wires from inside the dizzy to ecu for continuity. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-11-2012, 09:01 AM
Post: #34
Ok, so i unloom my engine harness and noticed a few wires that was cut but thats the way i recieved it from the guy i sent it to(owner of previously pheonix tuning but now called tweaked tuning). I chased them and a few went to the manifold ground. One went to the interior instrument panel plug. Looked it up and its for check ingine light which i already have on. Other tuan that all the wires for the ignition system looks to be good and have good continuity and going to there rightful places. Havent had time to put back together and install in car. Will probably try to this weekend but if not then ill keep you guys updated when i do.
Also, thanks again for everyones help and time. |
04-18-2012, 10:56 PM
Post: #35
is it running???
04-23-2012, 01:40 AM
Post: #36
Ok guys, im still getting the same thing with the same codes. Cant think of anything so whatever idea would be greatly appreciated. Here is a video of me trying to start it then using starting fluid to get it up and running. The idle holds good and but when i open the throttle up all the way. It would give a loud whistle then die.
Heres the vid https://www.youtube.com/watch?v=OPRhKySM...ata_player |
| Coil charge time | totta Crolla | 0 | 255 |
01-23-2026 07:27 AM Last Post: totta Crolla |
| lntermittent starting | totta Crolla | 6 | 5,860 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 4,329 |
| Hard start issue | kazi | 5 | 8,544 |
05-23-2017 11:31 PM Last Post: kazi |
| JDM trueno not starting. need help! | kazi | 8 | 11,486 |
