HELP!!! hard time starting
03-30-2012, 05:02 AM
Post: #31
I thought you´ve already done a diagnosis Banging head before we started with all the excessive investigation...
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
03-30-2012, 06:13 AM
Post: #32
Sorry but no. Remember, i got it to start so i didnt think i needed the diagnosis. Guess that shouldve been from point 1 huh. My bad on that one Banging head Confused
03-30-2012, 11:51 PM
Post: #33
Fu** yeah, takes only minutes to do and saves all the hassle with radondom checking for broken stuff.
Saved you from buying a 2nd pair of injectors...
Hope you get it sorted now. Easy as, on 4 AG(Z)E its either loose conectors or broken wires. Very uncommon for the actual electric part to fail.
Check the wires from inside the dizzy to ecu for continuity.
04-11-2012, 09:01 AM
Post: #34
Ok, so i unloom my engine harness and noticed a few wires that was cut but thats the way i recieved it from the guy i sent it to(owner of previously pheonix tuning but now called tweaked tuning). I chased them and a few went to the manifold ground. One went to the interior instrument panel plug. Looked it up and its for check ingine light which i already have on. Other tuan that all the wires for the ignition system looks to be good and have good continuity and going to there rightful places. Havent had time to put back together and install in car. Will probably try to this weekend but if not then ill keep you guys updated when i do.
Also, thanks again for everyones help and time.
04-18-2012, 10:56 PM
Post: #35
is it running???
04-23-2012, 01:40 AM
Post: #36
Ok guys, im still getting the same thing with the same codes. Cant think of anything so whatever idea would be greatly appreciated. Here is a video of me trying to start it then using starting fluid to get it up and running. The idle holds good and but when i open the throttle up all the way. It would give a loud whistle then die.
Heres the vid
https://www.youtube.com/watch?v=OPRhKySM...ata_player
  Coil charge time totta Crolla 0 615 01-23-2026 07:27 AM
Last Post: totta Crolla
  lntermittent starting totta Crolla 6 6,506 08-31-2021 06:21 PM
  Starting problems 4-AGE kouki Hanzo 3 4,833 08-31-2021 06:20 PM
  Hard start issue kazi 5 9,134 05-23-2017 11:31 PM
Last Post: kazi
  JDM trueno not starting. need help! kazi 8 12,221 03-12-2017 05:05 PM
Last Post: kazi
