Floor mat options in a track car
05-30-2010, 07:51 AM
Seems silly but... what options are out there that fit the AE86 chassis? I dont really want to hear my clutch pedal hit metal every time I shift gears.
05-30-2010, 10:42 AM
Glue some rubber to the back of the pedal?
05-30-2010, 10:50 AM
Not mats but Ive seen carbon fibre & checker plate versions.
here is an example, prob very expensive with the $ conversion http://www.galwaycarbon.com/car-parts/ae86-corolla/ An 86 is for Life, not just for Christmas |
05-30-2010, 11:11 AM
Those are some nice parts there...
I was thinking a rubber stop might be the best solution, but I also like the idea of protecting the paint in a high wear zone around the feet. |
05-30-2010, 11:16 AM
I would have thought that a mat would be the last thing that you would want floating around under your feet , if it isn't screwed or bolted down forget it .
Keep your original molded carpet or make some thing out of aluminum plate .I wouldn't have thought the clutch pedal should be going all the way to the floor ? Just my 2 cents worth . Your addiction to motorsport can only be cured by poverty !! |
Wide Track 86 | Mylesmck | 8 | 3,058 |
05-28-2023 09:51 PM Last Post: Bean |
ITB filter options | mister86 | 1 | 3,773 |
12-06-2020 10:44 AM Last Post: Bean |
AE86 starter options | max_ae86 | 12 | 32,076 |
07-28-2019 08:17 PM Last Post: harkes |
AE86 rear suspension options 2018 | Alex | 9 | 12,030 |
01-24-2018 02:25 PM Last Post: mad.matt |
Rear axle options | Dino86 | 13 | 14,243 |
