Fitting camber plates on shocks with odd threaded nuts
10-17-2007, 07:45 AM
Doc, did you put some sort of bush inside the camber plate? the shaft of the koni isn't big enough is it?
Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-17-2007, 08:24 AM
For the record / search function:
The same problem applies to camber plates paired with TRD Blue adjustable shocks. I used the stock nuts for the first ~4 months and encountered a horrible clonking noise that I couldn't allocate at first. Turns out I also couldn't tighten the nut on the camber plate correctly, so it had play. Use deep-type nuts for your upper mounts. ![]() |
10-17-2007, 09:43 AM
Fitting camber plates on shocks with odd threaded nuts | |||
10-17-2007, 11:40 AM
Mux213 Wrote:Doc, did you put some sort of bush inside the camber plate? the shaft of the koni isn't big enough is it? no, i only use the stock koni nut ![]() And my suspension is completely quiet ![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
10-17-2007, 12:47 PM
AshCampbell Wrote:http://www.aeu86.org/viewtopic/which-cam...highlight= Hahah, proves even an admin can create a double topic ![]() Thanks Ash, will look into merging these topics. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 5,467 |
01-07-2024 11:36 AM Last Post: CCB |
Fitting Fibreglass Kouki Lip? | chrisae86 | 3 | 2,836 |
02-25-2022 08:14 PM Last Post: chrisae86 |
rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 4,417 |
KONI Sports shocks for the AE86... | jondee86 | 11 | 22,760 |
Fitting driftworks CS2 coilovers | bozu | 2 | 5,369 |
05-30-2017 10:50 AM Last Post: bozu |
