Fitting camber plates on shocks with odd threaded nuts
10-17-2007, 07:45 AM
Doc, did you put some sort of bush inside the camber plate? the shaft of the koni isn't big enough is it?
10-17-2007, 08:24 AM
For the record / search function:
The same problem applies to camber plates paired with TRD Blue adjustable shocks. I used the stock nuts for the first ~4 months and encountered a horrible clonking noise that I couldn't allocate at first. Turns out I also couldn't tighten the nut on the camber plate correctly, so it had play. Use deep-type nuts for your upper mounts.
10-17-2007, 09:43 AM
| Fitting camber plates on shocks with odd threaded nuts | |||
10-17-2007, 11:40 AM
Mux213 Wrote:Doc, did you put some sort of bush inside the camber plate? the shaft of the koni isn't big enough is it? no, i only use the stock koni nut ![]() And my suspension is completely quiet
10-17-2007, 12:47 PM
AshCampbell Wrote:http://www.aeu86.org/viewtopic/which-cam...highlight= Hahah, proves even an admin can create a double topic ![]() Thanks Ash, will look into merging these topics. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
| Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 7,979 |
01-07-2024 11:36 AM Last Post: CCB |
| Fitting Fibreglass Kouki Lip? | chrisae86 | 3 | 4,123 |
02-25-2022 08:14 PM Last Post: chrisae86 |
| rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 6,232 |
| KONI Sports shocks for the AE86... | jondee86 | 11 | 26,344 |
| Fitting driftworks CS2 coilovers | bozu | 2 | 6,725 |
05-30-2017 10:50 AM Last Post: bozu |
