Family man's ae86
01-23-2020, 11:29 PM
Post: #51
Family man's ae86
The press is some nice home fabrication and the trumpets look good!
01-27-2020, 09:42 AM
(This post was last modified: 01-27-2020 09:44 AM by fantapants.)
Post: #52
Family man's ae86
Thanks man.
Been a bit slow with cash, but while I wait for bits to come in, I have managed to button up the fuel system. Well the bum anyway. . It's a ke70 tank, s13 cradle welded in with a Holley hydramat and walbro 255 pump. Again, it's a bits a. The main feed to the front is 3/8 Lol from when I was gunna run the uz. I'm using the old feed as the return. The cradle has 5/16 inlet and outlet, so there is some home made adaptors from a big old bolt. Not perfect but will get it running lol. Tank was given a birthday also, with internal seal paint thing done and a new coat of racing black outside. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk And more ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
01-27-2020, 02:40 PM
Post: #53
Family man's ae86
To be on the save side, You may want to add a short grounding wire from the chassis to the gas tank. Dave W
01-30-2020, 10:52 AM
(This post was last modified: 01-30-2020 10:56 AM by fantapants.)
Post: #54
Family man's ae86
Yeah that's the plan. There is a small earth for the cradle itself (it's isolated by the rubber oring) and I'll do one specifically for the tank also.
So I scrounge some cash up and got some pretty new 8.8 bolts for the rear end. Hurt a lot having to actually spend money lol. But managed a dry fit of the suspension and wheels. Good news, it all got a about as perfectly as I could have hoped for. Bad news, I need to remake the two top arms for chassis clearance lol. But all progress ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Forgot these bits. I had fucked up a bit with the tank and hadn't allocated for a breather. So did some hacking and welding and set up a breather from the tank cradle cap to the car hard lines ![]() Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
02-01-2020, 10:51 AM
Post: #55
Family man's ae86
Blech.
One of those days. Remade the front arms to clear the chassis. But cos I'm a dickhead, they didn't clear the cradle mount. Take 2 was more successful. Not exactly pretty, and I'll do it properly with some rod ends and chromemolly down the track, but this will get it going. ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
02-13-2020, 10:39 AM
(This post was last modified: 02-13-2020 10:43 AM by fantapants.)
Post: #56
Family man's ae86
Made a few small steps in progress.
Ran out of subtle black paint. See if you can pick where... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Today saw the wheels go on both sides of the car... the driver side has a bit more metal missing for suspension travel. I can tuck plenty of time before bottoming out. Will trim to match the other side shortly. Also sorted the bulk of the handbrake stiff. I'm not convinced it's a perfect solution, but will see how it goes. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
02-13-2020, 12:32 PM
Post: #57
Family man's ae86
Good progress, not too sure about the handbrake solution though..
02-16-2020, 01:01 PM
Post: #58
Family man's ae86
Yeah look the jury is out for the moment lol
Once I can get some pads in there I can give it a test pull and see. My brain says the stops are simply holding th3 force of the outer sliding against the internal cable, a d it's the cable that sees load. But I'm open to the idea that I fucked up lol once w ever some pads in I'll know soon enough. Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
05-13-2020, 10:33 AM
Post: #59
Family man's ae86
Sir, I commend you for being an engineer. I have been going through this thread and it looks really good. Amazing work, looking forward to the result and really curious how it will drive
07-13-2020, 10:48 AM
(This post was last modified: 07-13-2020 11:14 AM by fantapants.)
Post: #60
Family man's ae86
Sorry lads i lost tapatalk for a while.
Lots has been happening and progress has been made. I'll do a quick shoot through of where im at, but if you want any details hit me up and I'll try and answer anything. ![]() ![]() Sent from my SM-G960F using Tapatalk So been a while. I lost tapatalk for a bit after PayPal fucked my account. Anyways, once the worst of winter seemed over, I've managed a solid few weeks of progress. Old girl is dangerously close to some sort of achievement. I needed to relocate the car a bit for access to the front. Hence the gratuitous shot on 4 wheels. So i set about figuring out the engine position ans stuff. Gave up trying to be tricky abd used 20mm crossmember spacers for clearance. (Its ok, its treated pine..... :/ only temp to work out sizing. ) The eyeball work i did early on started to come back to bite me, with the shift position being too far forward. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk So set about making the engine and box a permamnat resident of the car. Started with the box end and worked forward. Clearance looks a bit tight iver the steering shaft, but its near 10mm at the closest Random colors simply cos i ran out of black lol made me a yondu bracket. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk As you can see in the last pics, the eyeball drug induced guestimations I did early on just keep on giving. The extractors were so badly on the piss lol. But I stoiclly ignored that and went on with the engine mounts. And thats the engine in its final spot. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk Sump clearance is okkkkkkk..... im gonna use a slimmer bolt and weld a small v shield informed of the bolt. It sits about 4 or5 mm below the cross member line. Also took the chance to finish off the front half of the exhaust. Made a poor mans slip joint at the front, And even out the rear bumper on to see how bad that build had gone lol. Actually was pretty good lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk Had a small victory with the stearing uni joint. Had been stressing over how to make up the difference with the dropped crossmember . In the end, I randomly tried a second uni joint from the other crossmember, turned out it was perfectly 20mm longer . Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk So I had to set about moving the shifter back a bit. As it sat, tbe gear stick was hard against the radio in 1st and 3rd lol Also sorted the reattachement of the radiator support panel. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk Needed trumpets for the throttles. This posed a problem s I had clearance issues with the brake booster and the bonnet lol. Eventuslly I plan on a booster delete to gain the space needed for a decent plenum, but for now, i present "the winky wonky donkey dicks" ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk One of my lesser moments was turning the old girl over on the rotiserie before i had the car port up lol. She filled with so much water i had to drill a small hole in the roof as a drain lol.. But that left the roof lining a bit worse for wesr. A few days with the heater going and a can of Mr sheen later, its came up not too shit lol. ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk One of my lesser moments was turning the old girl over on the rotiserie before i had the car port up lol. She filled with so much water i had to drill a small hole in the roof as a drain lol.. But that left the roof lining a bit worse for wesr. A few days with the heater going and a can of Mr sheen later, its came up not too shit lol. ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk Final bit of adventure so far is trying to sort out the manifold. I chopped her to bits and set about doing it in the car. Am using more slip joints for ease of making. And thats about it... need to sort a tailshaft out, and a million little bits and pieces, but she is progressing solidly. Hit a wall with the wiring. I'm just not confident enough with an entirely new skill lol. So a mate is gknna come and help me with that bit once the rest is sorted. I also have some rust work that needs doing, but its all easy to do while the csr is driving. At the moment, driving is the main goal. I can sort little bits like the longer lca and rust and proper trumpets and filter etc then. ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk So todays adventure were modest. I had hopes for getting the radiator mounting sorted. I used some commonwhore lower mounts (cheapest things i could find ) and made a bracket that bolts onto the lower sill. Had no idea how i was ganna make it work, but fumbled my way through the top mountz also. Figured i should chuck the bonnet on and see if things fit. Turns out i was a bit preemptive with winky wonly donky dicks, and the straight trumoets fits under the bonnet. So i have ummed and ahhed for ages about wanting to do a booster delete. I couldnt afford the grand chase bays wants for their tidy little setup. But did some thinking and measuring and have bitten the bullet on a plan. If i redrill the pedal 25mm further up, i gain a pedal ratio of 6.1 to 1. That seems the go to for manual brakes. Ive ordered a bm44 2 port master, a chunk of aluminium for the adaptor plate, and am waiting on a gktech abs delete hose kit. This kit should bolt everything up and finalise the brake setup (lines anyways lol) the booster delete means i should be able to remove the last of the winky wonky donkey dicks lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
| Banpei's new TA60 family cruiser | banpei | 281 | 338,995 |
10-30-2024 11:48 PM Last Post: DarkSupra |
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/a3a23d5436cb91c34163564823441a96.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/1f79947aff248d06aac2cc3d96a21997.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/b7a1f10fa7b7f2e31e2eabbc51b00e93.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/340294678f503158bd220572e4904dce.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/7e822521989d27b54ca67ffbd76863e5.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/120d97828d2d7602b7be0bdc93edd183.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/9c725852235146219161e01a2cf2784a.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/16c943d4489ff595853a3b9c61e79aed.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/15f0edf11516ac99091f9e1146ccd730.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/7907bfb2ff8a5e16bc8600bccb46e310.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/ebd2bca1c7bcf82e7bfbee16510a408e.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/8185089bc288f3b50317126d2a9eafbf.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200127/0642f28bb91685cb06d9b008250f147b.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200130/20b707de7fead9120c7d4ed8186cf16b.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200130/0e677967f6ac0d17149b97ff445f7ace.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200130/415b25ed2422d81f4da198ebef8b1ae0.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200130/b2b1b91d62b510b89d2a14acd0824ff6.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200130/215362edcaff6b8dcb718d67f80bf1e0.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200130/58c1b2b57c51e30d67d25878b9843462.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200130/6b67d019297fbc8b9a00065de3be8c71.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200130/818849ce38552b6afdf94b0489931110.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200130/e1fc0996f493555868ceffc01856b341.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200201/54b841090e11bbb2e58be9eb1d841416.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200201/ef05bbdfbe8f63e020a13bf0c0b692db.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200201/f37a98009e0fb8e666ccff88b580b2c3.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200201/0330e0bb9613fbfaeedfbc7d22db6d3c.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/40cc9cfd69080a8d3f126d7ab97b0447.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/91daed7c228f9ef5e5757bd084899afc.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/87a47c9ee04a0847e16855164263bd5c.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/08b5429b779cc8fce83d19fa847208c5.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/c3e66e5dbc251dd2992489e49c7d2e02.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/46b030e79786478c7bf6b08f9aeebb54.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/53d3628c70d1454b33fb4e132a1acfa1.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/3c3d03181682e69a571268df0612d8ef.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/19b55ed2d2293e1b2367240869bc0964.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/f4afa60f4eddab29b8becc5cbb891baf.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/64857f7f3bbe12224e82b6611db71683.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/f4b7d726978093b2dbf4843e250fd31e.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/b67852906dfa36d826a11ebc57df4a93.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/6d041162ef74825d46c1f8a2a4fe8e48.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/5a40d21ecc387e86074aceff31dd5ca4.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200213/b4f85962f0c0173ab2d1fa5e5122d23d.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/c2a4ccf97e4d8d202e918f69fb318393.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/27e7c33693d78e1e7d92a6eace30b2c6.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/d2f67d3d7ffacf24ce1be7f089955d0e.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/ae03e76a29734beaf6bcafbc48d3fde6.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/ba51b327d94ccbc58c6c2a7a6f49c3de.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/1e8d77753427132980e05e558a4235b4.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/099df1c2046c60b06f5aaf180fd59402.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/c9a0524a23dc0ee7830240256b277a54.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/2d98cb177e6738dfed1f88176e1a1e41.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/908a9b645b177278ea60ee1337790fe1.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/f4ff674432f8da8aa6f854ee21c84454.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/392cde9d6ba659a0721fa5e9fad87d2f.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/f1d8df829bc3598cc7ee7495691ee2bc.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/5618e2166cc954b13ed8e9bc63d4a601.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/9d99d8da03bc76c98f9ba7b2cb4d7088.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/0b5fd6fb820ec2bd5d66afb23bc51cb2.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/7cdea55bf8489d0876797b4a7281cb65.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/018369e8041059813f3f1d06ecbbcf19.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/b6aac037126ab21b400a8cb8ff523d5a.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/0e5de5df52af243001a4585036614dbb.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/aeca7c0b05c6f6d9a92788d754db1368.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/98bd50213b4e55cd6fae7d5d074a445a.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/eb05cd9cfe6d5ab88133c3e10c10d35f.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/8d4cc3ba3800cc7b4b538dfbedffe7ec.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/0b5d081ce59c4bf88611f51b2a728fab.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/65ff711616363637e8cbae3398ec667e.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/7ece6990ea3e2d750fc7bd7182881403.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/c500f94e550235a57259531c5bd07b4a.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/752c847cfec2ba8416dc00c70fc75419.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/fc1cd8d06cc2d6738a4e3d998b11fd7c.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/abad750eb78f3a3767c4c2cfbfd6cb19.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/a28d4bab9bd6a587180c51197f336cce.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/da2135a565e61463a405f700fc934066.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/395191e5b681d2f7ed117d5eca5cb503.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/b865bb3ae95615ff4063ceeff4677699.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/7374d50e169dee98cad1b81b2a0109bc.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/d46cb86cb92bf7c790dc685e2d596ba6.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/c2e1588b5b0379857cb82ba5c234e2ac.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/e51afa478529d75571f50421318b731f.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/88d641bf57d2d5ee3b8e84f23411f537.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/1f5fc895bedf9894f1ff4d04f99ba3b0.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/12f3d076bcd58add9d639cdb205dcddc.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/bf4ec4c17c2ba573d37d7a9ed018cc4e.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/b1243bd9ff2a61afdaa007515c0ea53c.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/e29574b840456feb77963626ce530e85.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/373495b8b861b169b7fff5a214d9f0dc.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/2a49b5dd1498a1013bb8e3b21c26b4d2.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/6d256912c2beae32d110e0412489d681.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/4e9d26ba0f90fd88a13f3062f5e29828.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/34f9c15a40801c0552122ca8559969cd.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/bf19d21f37796b88684b24b567bc879d.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/cb2928bfede1b5dbe28acea02f182ffc.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/e525bcc485f2dc0b935062e90d377d9d.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/90ef5e5a0a4c9cb968ead60cf4665df1.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/2ebd52b8fbe0c2d99b386ec6f45ec972.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/f2f6ad0d83e5f23579be357bce0851cc.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/567562c8ef36ab226bed5f15137779dc.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200711/716d1e7d906fd5ee0fea460c5d240272.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/bd9ac004385f90508ecca7ee382b882b.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/5cdd1db43fdd8a416127394084b12958.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/de7d88af0d7b6e47afe6c39665d6eecb.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/a065ad15c556af43bae1ba1358eae82a.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/d50e076a498097a349fad351737fe64f.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/de5b32e725579e3ddcb01d12127056ca.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/f6d73408ae34c8dcabc16cf7e1bfc046.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/221fe87604129e6f5af5b1fb717fba8c.jpg)
![AEU86 AE86 - Family man's ae86 [Image: AEU86 AE86 - Family man's ae86]](https://uploads.tapatalk-cdn.com/20200713/a4a25c419469908022b3f1d4e304cd9e.jpg)
