Family man's ae86
01-23-2020, 11:29 PM
Post: #51
Family man's ae86
The press is some nice home fabrication and the trumpets look good! Thumbs up!
[Image: AEU86 AE86 - Family man's ae86]
01-27-2020, 09:42 AM (This post was last modified: 01-27-2020 09:44 AM by fantapants.)
Post: #52
Family man's ae86
Thanks man.
Been a bit slow with cash, but while I wait for bits to come in, I have managed to button up the fuel system.
Well the bum anyway. .
It's a ke70 tank, s13 cradle welded in with a Holley hydramat and walbro 255 pump. Again, it's a bits a. The main feed to the front is 3/8 Lol from when I was gunna run the uz. I'm using the old feed as the return.
The cradle has 5/16 inlet and outlet, so there is some home made adaptors from a big old bolt. Not perfect but will get it running lol. Tank was given a birthday also, with internal seal paint thing done and a new coat of racing black outside. [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
Sent from my SM-G960F using Tapatalk
And more [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
clutch kick, switch, tree .... oowwww
01-27-2020, 02:40 PM
Post: #53
Family man's ae86
To be on the save side, You may want to add a short grounding wire from the chassis to the gas tank. Dave W
01-30-2020, 10:52 AM (This post was last modified: 01-30-2020 10:56 AM by fantapants.)
Post: #54
Family man's ae86
Yeah that's the plan. There is a small earth for the cradle itself (it's isolated by the rubber oring) and I'll do one specifically for the tank also.
So I scrounge some cash up and got some pretty new 8.8 bolts for the rear end. Hurt a lot having to actually spend money lol.
But managed a dry fit of the suspension and wheels.
Good news, it all got a about as perfectly as I could have hoped for.
Bad news, I need to remake the two top arms for chassis clearance lol.
But all progress
Forgot these bits.
I had fucked up a bit with the tank and hadn't allocated for a breather. So did some hacking and welding and set up a breather from the tank cradle cap to the car hard lines [Image: AEU86 AE86 - Family man's ae86]
02-01-2020, 10:51 AM
Post: #55
Family man's ae86
Blech.
One of those days.
Remade the front arms to clear the chassis. But cos I'm a dickhead, they didn't clear the cradle mount.
Take 2 was more successful. Not exactly pretty, and I'll do it properly with some rod ends and chromemolly down the track, but this will get it going.[Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
02-13-2020, 10:39 AM (This post was last modified: 02-13-2020 10:43 AM by fantapants.)
Post: #56
Family man's ae86
Made a few small steps in progress.
Ran out of subtle black paint. See if you can pick where... [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
Today saw the wheels go on both sides of the car... the driver side has a bit more metal missing for suspension travel. I can tuck plenty of time before bottoming out. Will trim to match the other side shortly. Also sorted the bulk of the handbrake stiff. I'm not convinced it's a perfect solution, but will see how it goes. [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
02-13-2020, 12:32 PM
Post: #57
Family man's ae86
Good progress, not too sure about the handbrake solution though..
02-16-2020, 01:01 PM
Post: #58
Family man's ae86
Yeah look the jury is out for the moment lol
Once I can get some pads in there I can give it a test pull and see. My brain says the stops are simply holding th3 force of the outer sliding against the internal cable, a d it's the cable that sees load.
But I'm open to the idea that I fucked up lol once w ever some pads in I'll know soon enough.
05-13-2020, 10:33 AM
Post: #59
Family man's ae86
Sir, I commend you for being an engineer. I have been going through this thread and it looks really good. Amazing work, looking forward to the result and really curious how it will drive Smile
07-13-2020, 10:48 AM (This post was last modified: 07-13-2020 11:14 AM by fantapants.)
Post: #60
Family man's ae86
Sorry lads i lost tapatalk for a while.
Lots has been happening and progress has been made. I'll do a quick shoot through of where im at, but if you want any details hit me up and I'll try and answer anything.
So been a while. I lost tapatalk for a bit after PayPal fucked my account.
Anyways, once the worst of winter seemed over, I've managed a solid few weeks of progress. Old girl is dangerously close to some sort of achievement.
I needed to relocate the car a bit for access to the front. Hence the gratuitous shot on 4 wheels. So i set about figuring out the engine position ans stuff. Gave up trying to be tricky abd used 20mm crossmember spacers for clearance. (Its ok, its treated pine..... :/ only temp to work out sizing. ) The eyeball work i did early on started to come back to bite me, with the shift position being too far forward.[Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
So set about making the engine and box a permamnat resident of the car.
Started with the box end and worked forward. Clearance looks a bit tight iver the steering shaft, but its near 10mm at the closest
Random colors simply cos i ran out of black lol made me a yondu bracket. [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
As you can see in the last pics, the eyeball drug induced guestimations I did early on just keep on giving. The extractors were so badly on the piss lol.
But I stoiclly ignored that and went on with the engine mounts. And thats the engine in its final spot. [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
Sump clearance is okkkkkkk..... im gonna use a slimmer bolt and weld a small v shield informed of the bolt. It sits about 4 or5 mm below the cross member line.
Also took the chance to finish off the front half of the exhaust. Made a poor mans slip joint at the front,
And even out the rear bumper on to see how bad that build had gone lol. Actually was pretty good lol [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
Had a small victory with the stearing uni joint. Had been stressing over how to make up the difference with the dropped crossmember . In the end, I randomly tried a second uni joint from the other crossmember, turned out it was perfectly 20mm longer .
So I had to set about moving the shifter back a bit. As it sat, tbe gear stick was hard against the radio in 1st and 3rd lol
Also sorted the reattachement of the radiator support panel. [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
Needed trumpets for the throttles.
This posed a problem s I had clearance issues with the brake booster and the bonnet lol.
Eventuslly I plan on a booster delete to gain the space needed for a decent plenum, but for now, i present "the winky wonky donkey dicks" [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
One of my lesser moments was turning the old girl over on the rotiserie before i had the car port up lol. She filled with so much water i had to drill a small hole in the roof as a drain lol..
But that left the roof lining a bit worse for wesr.
A few days with the heater going and a can of Mr sheen later, its came up not too shit lol. [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
Final bit of adventure so far is trying to sort out the manifold.
I chopped her to bits and set about doing it in the car.
Am using more slip joints for ease of making.
And thats about it... need to sort a tailshaft out, and a million little bits and pieces, but she is progressing solidly.
Hit a wall with the wiring. I'm just not confident enough with an entirely new skill lol. So a mate is gknna come and help me with that bit once the rest is sorted.
I also have some rust work that needs doing, but its all easy to do while the csr is driving. At the moment, driving is the main goal. I can sort little bits like the longer lca and rust and proper trumpets and filter etc then. [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
So todays adventure were modest. I had hopes for getting the radiator mounting sorted.
I used some commonwhore lower mounts (cheapest things i could find ) and made a bracket that bolts onto the lower sill. Had no idea how i was ganna make it work, but fumbled my way through the top mountz also.
Figured i should chuck the bonnet on and see if things fit.
Turns out i was a bit preemptive with winky wonly donky dicks, and the straight trumoets fits under the bonnet.
So i have ummed and ahhed for ages about wanting to do a booster delete. I couldnt afford the grand chase bays wants for their tidy little setup.
But did some thinking and measuring and have bitten the bullet on a plan. If i redrill the pedal 25mm further up, i gain a pedal ratio of 6.1 to 1. That seems the go to for manual brakes. Ive ordered a bm44 2 port master, a chunk of aluminium for the adaptor plate, and am waiting on a gktech abs delete hose kit. This kit should bolt everything up and finalise the brake setup (lines anyways lol) the booster delete means i should be able to remove the last of the winky wonky donkey dicks lol [Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86][Image: AEU86 AE86 - Family man's ae86]
  Banpei's new TA60 family cruiser banpei 281 295,411 10-30-2024 11:48 PM
Last Post: DarkSupra
