Electric fan size
09-11-2008, 10:48 PM
Electric fan size
Hi
I have plans fitting an electrical fan on my radiator in my 86. I have bought the thermostat and only lack the fan it self. My question is: How heigh is the stock radiator? I'm not close to mine at the moment so I can't measure it. I can choose between 10, 12 and 14 inch fans. Have anyone mounted an electrical fan? What is you experience? What setup did you make? Cheers Martin AE86 - 4AGE - 1984 My project - http://www.aeu86.org/viewtopic/another-d...on/t/13190 |
09-12-2008, 12:24 AM
Electric fan size
AFAIK it is 12" high.
I'm about to buy one also. Best regards |
09-22-2008, 04:20 AM
Electric fan size
I suggest getting symmetrical fans with an even amount of fins. From what I have researched this makes for the best flow.
09-22-2008, 07:34 AM
Electric fan size
Hi
I not quite sure I follow you. Do you mean two on one side or one on each side? I guess one on each side would give a very high air flow. /Martin AE86 - 4AGE - 1984 My project - http://www.aeu86.org/viewtopic/another-d...on/t/13190 |
10-14-2008, 05:59 AM
Electric fan size
Just make sure that your flan is slim enough and that there are an even amount of fins to make sure that you have the best flow.
| Electric windows | totta Crolla | 0 | 1,889 |
03-18-2025 11:00 PM Last Post: totta Crolla |
| Shim size for AM cams | kazi | 4 | 7,908 |
| Hub size | kazi | 5 | 12,753 |
| Camshaft sprocket bolt size? | harkes | 1 | 6,392 |
| Oil plug thread size is M18x1.5 ???? | Dino86 | 5 | 12,393 |
