Econ light doesn't work
10-06-2005, 08:35 AM
I've got a problem, the green Econ light on the dash doesn't work any more.
The car idles normally (about 1500rpm when cold, and 900 rpm when warm). When I step on the gas pedal, the PWR indicator (orange light)switches on like always.
I know, that I should check the bulb first, but I'm wondering if I have to dismant the dashboard or is there any possibility to check the signal to the light without dismanting the dash?
Do you know, how the econ meter is working? There's something in connection with "Vacuum switch" as seen in the manual (photo attached).
Where is this vacuum switch located?
TNX in advance
Andrej
10-06-2005, 08:57 AM
The vacuum switch is located next to the airfilter, it is attached with 1 wire and has a rubber boot on top of it.
If your PWR light does switch on and is not permanently switched on then you have a broken lightbulb. If it is always orange, or always green then you have a problem with the vacuum switch.
10-06-2005, 10:15 AM
To switch it you need to take off the black-housing. It is a bit tricky but I managed to do it without removing my steeringwheel. It might be easier to remove the steeringwheel and then the housing. Smile
After that you can remove the display. Smile
The econometer is the second thread (from left) on the second connector (from left), so you can also check that one, but I don't think its broken. I'd say its the lightbulb. Wink
[Image: AEU86 AE86 - Econ light doesn't work]
10-06-2005, 11:22 AM
Tnx for the answers Smile
The yellow light goes on and off normally, so I expect faulty bulb of the green light.
So I'll have to dissasemble the dashboard again Sad
Regards
Andrej
  ECON and PWR light troubleshooting magpie 3 4,420 07-18-2023 01:28 PM
  Weak spark, doesn’t start. AlexFourTwenty 4 18,860 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
  How seatbelt rails work? FanIsHere 2 6,673 05-18-2016 09:52 AM
  my last work , Dentist needed filh 5 8,854 03-29-2013 07:47 AM
Last Post: assassin10000
  How does the 4age AFM system work? heshan 22 32,841 12-20-2012 05:01 AM
Last Post: heshan
