Dual circuit brakes
11-07-2005, 11:46 AM
Dual circuit brakes
Can anyone tell me how the dual circuit brakes are 'split' is it front/rear or diagonal ?
I want to fit a bias valve and need to know this thanks.
Also does the car have a factory set bias valve ?
11-07-2005, 11:56 AM
Dual circuit brakes
It's split front/rear...I dunno about the factory bias, but there is a splitter under the master cilinder (mounted against the strut tower) that might have some biasing functionality..but I'm not sure about that.
11-07-2005, 12:08 PM
Dual circuit brakes
This splitter has integrated bias valve. You must remove it, make your own "T" splitter (2 lines for each front caliper and one line to rear end) and put your bias valve to the line to rear end. Avoid using 2 bias valves in one circuit !!!
11-07-2005, 12:18 PM
Dual circuit brakes
Thumbs up!
Fantastic response, I can get on with it today now.... Thanks guys !!
  Rear brakes totta Crolla 0 1,352 02-03-2023 12:54 PM
Last Post: totta Crolla
  Switching diffs for disc brakes? trippin 6 3,960 07-08-2022 03:35 AM
Last Post: trippin
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 4,202 12-21-2016 09:37 PM
Last Post: bozu
  Hydraulic handbrake with stock rear brakes Dino86 11 17,505 07-11-2014 08:33 PM
Last Post: Dino86
  S13 Front brakes in AE86 rear heshan 25 31,597 02-01-2014 12:37 PM
Last Post: heshan
