Drifting with stock power on the dry
04-15-2007, 06:10 PM
HI!
I was a bit "drifting" today, now with the kaaz 2 way lsd i got much more grip on the dry, i have 195 tyres on 15 inch wheels with koni suspension on the car. its very tricky to get the hachi roku sideways, i am not using e-brake technique i dont like that.... |
04-15-2007, 06:30 PM
use shittier tires, more revs and increase pressure in the reartires to ~40psi or more
![]() one or all of the above should do the trick
AE86 ex-daily |
04-15-2007, 06:33 PM
http://www.youtube.com/watch?v=h4idoFNGxOg
http://www.youtube.com/watch?v=44r4Sj8zLyo This are some first tryouts with the ae, it was on a cold day, so the tyres didn´t grip much, i know not much angle but good speed i think |
04-15-2007, 06:39 PM
I had the same probelm in the beginning, and also thought that i had to much grip,but its simple becource you are going to slow!,
And that is not my trying to say anything about your driving, But that was the same with me, With the hachi, you need to go fast ,at the entry, it´s alot easy´er when you get more power,then you can drift at a lower speed, but it´s also much more fun to do it faster, becourse there is not much power over drift anyway, So drift from the entry of the corner /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
04-15-2007, 07:08 PM
I come to this corner in third gear, maybe 100-110km/h then i brake late, still in third gear, steer in and shift down to second without toe and heel, then the rear brakes out...
04-15-2007, 08:18 PM
get the Camber done Ash... we talked about it already... you will be having more fun... especially with the KAAZ pusching so much your front end needs to have more grip!!!
04-15-2007, 08:27 PM
yeah bro i know, my front tyres smoke more then my rear ones do
04-15-2007, 10:21 PM
it should be the other way around!!! or are you driving a AUDI?
no for real... camberplates... about 1.8 of camber and your Konis set to 3/4 front and 3,5/4 rear... you will have nice balance and no more understeer!! I had the same Setup with the Kaaz 2 way before... that was a nice setup... now I will run Greddy Type S + Cusco RS LSD... I think i will feel the difference!!!
04-16-2007, 10:19 AM
why did you change your lsd?
04-16-2007, 12:54 PM
the Kaaz didn't make the effect I wanted... the Cusco RS works with lower torghe because of the spring layout... the Kaaz works with the disc layout... Kaaz is good... but Cusco RS is the something else
| Best setup for drifting... | Okami | 68 | 108,487 |
01-19-2012 11:20 PM Last Post: Okami |
| Drifting Lelystad New Vid check bottom | Okami | 9 | 19,232 |
03-14-2011 10:47 PM Last Post: Okami |
| DRIFTING IN ROMANIA | spawns | 5 | 11,108 |
09-09-2010 01:32 PM Last Post: spawns |
| Indie feature documentary on drifting – calls for stories | emptykingdom | 2 | 10,146 |
05-18-2010 12:05 PM Last Post: Okami |
| What do you like about drifting...? | heshan | 1 | 5,240 |
09-27-2009 06:51 AM Last Post: heshan |
