Does 4x100 wheels go on hachi
05-14-2006, 09:47 PM
I am little bit confused...does 4x100 go on hachi or not?
05-14-2006, 10:03 PM
No, you will will need an adapter to make it fit... An AE86 has a 4x114,3 pattern.
05-15-2006, 01:37 PM
Jan Pedersen Wrote:No, you will will need an adapter to make it fit... An AE86 has a 4x114,3 pattern.In fact there is another workaround - redrilling the stock wheel hubs. I must check is it easy to do |
05-15-2006, 02:34 PM
Do you think it's a good idea? You have to drill the brake rotors, the halfshafts (rear). They will be weakened because of this...
05-15-2006, 02:39 PM
SutteR Wrote:Do you think it's a good idea? You have to drill the brake rotors, the halfshafts (rear). They will be weakened because of this... I'm sure that they will be at least stronger than wheel adapters. There is no reason for any kind of weakening. |
| Anyone know what this plug does? | Super86 | 3 | 8,290 |
08-01-2016 03:57 PM Last Post: Nakilad |
| How does the 4age AFM system work? | heshan | 22 | 30,970 |
12-20-2012 05:01 AM Last Post: heshan |
| 4x100 conversion | Eifelaner | 22 | 26,468 |
12-08-2012 01:14 AM Last Post: Eifelaner |
| MSD 8980 setup - which wire does the dizzy connect to? | megabob | 8 | 20,034 |
11-22-2011 07:02 PM Last Post: Project D |
| Does anyone know where to buy a short steering hub/boss? | krullibull | 6 | 8,678 |
10-12-2011 10:26 PM Last Post: krullibull |
