Doc's KE20: - really coming together now
03-22-2007, 06:49 PM
Post: #251
there's a company selling bacterias(LVN Biopruducts BV i NL should have them) which can be used as oil remover. You just mix the bacterias(powder) with water and pour it over the oil spot.
no harm to the enviroment
Philip |
03-22-2007, 06:56 PM
Post: #252
banpei Wrote:Nice! jup, but my own gauge will fit in there
03-23-2007, 09:17 AM
Post: #253
Ah right... You probably don't have a whole cluster like the ae86.
04-02-2007, 11:22 PM
Post: #254
![]() It's in! I also put in the TE27 centre console, but i didn't wire them yet. I did it, because someone was interested in my stock centre console, so i swapped it in
04-03-2007, 12:41 PM
Post: #255
Nice!
05-11-2007, 04:11 PM
Post: #256
Today i finally got some time to finish the tuned head off (i know i work slower then my car drives atm!
![]() Since the donor car i have, has a blown head gasket and the head is pulled of, i had a chance to compare stock 1.2 to the tuned 1.3 head: ![]() From a guy from the UK, who is swapping a 1500cc 5K in his Toyota 1000 i heard that the engine didn't fit in his car. I know a Toyota 1000 is a bit smaller then a Corolla, but i never was sure that it would fit. So i again went to the yellow donor car to testfit the manifold+carbs+stacks on it ![]() And they fit..... just ![]() ![]() ![]() I guess i need the thinnest gaskets for the webers as i can find I do have got some things to fit the webers better and less wobbly, but they are 1cm thick, and that would mean, the carbs don't fit more And then i heard that the 1.2 head is junk, because there's a big hole in an oil channel, i needed to think what i could do with the stuff from the 1.2 head ![]() Candle holders, someone?
05-11-2007, 05:40 PM
Post: #257
Hey Doc,
Arent you going to get serious airflow problems that way? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
05-11-2007, 05:48 PM
Post: #258
dunno, maybe i need some shorter stacks, but i'll see that when it's finished and in the car
05-11-2007, 11:14 PM
Post: #259
airbox should do the trick. instead of the horns. or simulate the 20v itb stack. the inlet goes down i believe
05-12-2007, 05:03 PM
Post: #260
Airbox wont do the trick I'm affraid. A race engineer once told me that in order to visualise the airflow into a bell mouth, he usually though of (or actually used) a tennisball sitting on the bellmouth. That is more or less the area directly affected by the intake. The flowlines in the current situation are a serious compromise...maybe the situation can be improved by milling down the intake adapter and using an ultra short horn, but using the pair of downdrafts seems to be your cheapest option.
| Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 99,602 |
06-22-2015 02:56 PM Last Post: Uzelac |
| My little (not really...) project - Soon to be all done?!? | Jan Pedersen | 516 | 669,083 |
| AE86 from Portugal (restoring gearbox now...) | Homem Bomba | 13 | 25,873 |
01-01-2013 11:45 PM Last Post: Homem Bomba |
| Levin Coupe from Croatia - NOW SR86 with IRS | ZaX | 698 | 852,846 |
10-01-2012 08:07 PM Last Post: ZaX |
| Ricks project AE85 (Back together with dyno results) | Rick | 132 | 253,028 |
07-05-2011 11:54 AM Last Post: Rick |
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/dashgemonteerd.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/Project4K/kop-09.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/Project4K/kopverschil.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/Project4K/carbspassen-01.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/Project4K/carbspassen-02.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/Project4K/carbspassen-03.jpg)
