Doc's KE20: - really coming together now
10-08-2006, 07:23 PM
Post: #171
Ah.. a familiar sight. I'd forgotten how badly that wheel was battered to death by mux, but you only need 2 anyway so you're in luck with that.
10-08-2006, 07:49 PM
Post: #172
Ivan141 Wrote:Ah.. a familiar sight. I'd forgotten how badly that wheel was battered to death by mux, but you only need 2 anyway so you're in luck with that.I live to serve Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-08-2006, 08:54 PM
Post: #173
damn, that beat up wheel looks just scary in daylight!
Did you use a jackhammer to get it off? I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
10-08-2006, 09:20 PM
Post: #174
Nopez, "Moker"
10-14-2006, 10:56 PM
Post: #175
well, today i swapped the front struts with new brakes and stuff.
Pics will come later, when D.Wars uploads them. I must say: BIG thanks to Damir, Ivan, Dennis and Rico (not on this forum). Without them, it would've never happend i guess ![]() Now it's time to finish up some small things, something is scratching the disk when braking, and they feel a bit soft by now, need to re-bleed i think. But everything fitted very well, so it's a straight swap
10-15-2006, 11:08 AM
Post: #176
Doc, if the noise is coming from the left front caliper then have a good look at the anti squeel shims, the outside pad went in with some difficulty.
It's a good thing I'm used to working with seized up old crap these days, cause there was plenty of it on both your and NoHachi's cars. FABRICA MI DIEM, PVNC! |
10-15-2006, 11:32 AM
Post: #177
Ivan141 Wrote:It's a good thing I'm used to working with seized up old crap these days, cause there was plenty of it on both your and NoHachi's cars. This afternoon Doc and I are going to re-bleed again. It was quite a day yesterday. But I did enjoyed it! Thomas is uploading the pictures as we speak, i think. Everyone big thanks for the help (with the precision tools also I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
10-15-2006, 11:34 AM
Post: #178
Ivan141 Wrote:Doc, if the noise is coming from the left front caliper then have a good look at the anti squeel shims, the outside pad went in with some difficulty. it think it's the bolt causing the problem, i didn't fit some washers behind the callipermountbolts
10-15-2006, 11:49 AM
Post: #179
at first, we started with a starlet, it needed some new shocks
![]() ![]() ![]() ![]() This guy would let me use his shed with a bridge in it and powertools. Very nice guy! ![]() Then it was time for me Getting rid of the old shit: ![]() When i got the strut away, i 'only' needed to remove the steering arms, which wouldn't get out of their position. At that time Ivan and Damir arrived, and they solved the problem (after a long time bashing on the bolts/steering arm etc. etc.) with a 'dutch screwdriver' ![]() 3 hours after i started, the AE struts where finally on: ![]() installing the brake bits on 2 sides: ![]() Spot the difference ![]() ![]() 'new' wheels (4x114,3 ![]() Checking: ![]() Looks nice, doesn't it? ![]() Ready! ![]() Then it was time to move on to Damir's KE25, he needed an other driveshaft (according to the MOT-man....., it was in perfect shape) and a new exhaust. The exhaust was quite hard to install, almost NO space to reach the nuts and bolts ![]() ![]() After all, it was a day (started around 10 am, finished around 9 pm ) of things which went well, broken bolts and reluctant old Toyota shit
10-15-2006, 12:52 PM
Post: #180
Good job!
So when are mux's wolfrace rims going to be mounted?
| Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 103,562 |
| My little (not really...) project - Soon to be all done?!? | Jan Pedersen | 516 | 699,588 |
| AE86 from Portugal (restoring gearbox now...) | Homem Bomba | 13 | 26,847 |
01-01-2013 11:45 PM Last Post: Homem Bomba |
| Levin Coupe from Croatia - NOW SR86 with IRS | ZaX | 698 | 893,692 |
10-01-2012 08:07 PM Last Post: ZaX |
| Ricks project AE85 (Back together with dyno results) | Rick | 132 | 262,962 |
07-05-2011 11:54 AM Last Post: Rick |
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/Starlet-01.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/Starlet-02.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/Starlet-03.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-01.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-02.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-03.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-04.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-05.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-06.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-07.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-08.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-09.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KEtoAE-10.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KE25-01.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](http://www.uwhost4.net/~hachi/beunen/KE25-02.jpg)
![AEU86 AE86 - Doc's KE20: - really coming together now [Image: AEU86 AE86 - Doc's KE20: - really coming together now]](https://www.aeu86.org/sticker-banner-468.gif)
