Disconnecting the MAP?
03-31-2009, 05:59 PM
I am pretty sure I know this but I have forgotten. I forget alot these days!
Can anyone tell me what the effect of disconnecting the MAP sesnor would be on the engines running? We are talking a stock engine here.
Overfuel, limp mode, or would the engine still run fine relying on the TPS.
[Image: AEU86 AE86 - Disconnecting the MAP?]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
03-31-2009, 07:09 PM
both spak and fuel maps are primarly based on the map sensor.
So you car won't run very well ...
The TPS is only used when your accelerator position is changing
03-31-2009, 09:20 PM
Yes... what ^^^^ he said. If you disconnect the hose, the MAP sensor
is reading atmospheric pressure which = WOT. Therefore the engine
will be running rich/very rich at anything less than WOT.
Cheers... jondee86
04-01-2009, 10:49 PM
what if you have a 20v silver top. I heard you can plug in the black top ecu and just go. is this correct?
<a href="http://s207.photobucket.com/albums/bb160/Import_Prophetz/?action=view&current=toyota-trueno-1.png" target="_blank"><img src="http://i207.photobucket.com/albums/bb160/Import_Prophetz/toyota-trueno-1.png" border="0" alt="Photobucket"></a>
04-02-2009, 08:56 AM
Import_ProphetZ Wrote:what if you have a 20v silver top. I heard you can plug in the black top ecu and just go. is this correct?
No. You would have to do a AFM to MAP conversion. From what I read
it causes more problems than it provides benefits. Because of the bigger
throttles, the BT seems to run a different fuel map to the ST, and this
causes all sorts of running rich headaches !!!
Cheers... jondee86
04-06-2010, 12:39 PM
Hi...I tried disconnnecting the hose of my MAP sensor and the engine died..what could be the possible problem? wiring?
04-06-2010, 01:16 PM
Why did you disconnect it? Its the main sensor for the ecu in non-AFM cars.
04-06-2010, 10:15 PM
Longhorn Wrote:Hi...I tried disconnnecting the hose of my MAP sensor and the engine
The problem was you disconnected the hose.... Dumb question
Cheers... jondee86
Big Grin map sensor cheating? fdsjakl890 8 4,351 08-26-2025 01:12 PM
  AFM to Map Conversion ps13michi 3 6,698 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 19,399 02-10-2020 06:39 PM
Last Post: Power_uP
  extracted freedom ecu 16v ignition map ditn 7 13,252 08-22-2016 10:01 AM
Last Post: ditn
  smallport question AFM or MAP? fax0815 5 11,777 05-17-2014 05:07 AM
Last Post: jondee86
