Dimensions wheel studs?
03-04-2007, 05:58 PM
Just discovered that one of my rear wheel studs broke off, causing rattling sounds while driving. One half of the stud is still in the hub/brakedisc. Can I just remove it by tapping it out from the front?
Okay but my reallll question was...what are the dimensions of the wheel stud?? couldnt find it... (I have standard 14" pizzacutters, if relevant)
Any (Dutch) shop you guys recommend?? Thumbs up!
(something like this http://www.biesheuvel.nl/shop/cat/71/stud_bolts ?)
also..do i need remove the brake disc and all the other things to change the studs? If i know these steps beforehand, hopefully it wont take too long Smile
An '86 86 driver
Zenki AE86 Levin coupe
03-04-2007, 10:01 PM
I have front wheel stud on my desk now.
03-05-2007, 11:02 AM
so 25.5 mms protrude out from the hub? If one bought 25 mm spacers with 4x100 studs, would this spacer acomondatte for the studs to be bolted down/hidden?
03-05-2007, 11:16 AM
Yes, Apolan. That's why I always recommend 25+mm thick wheel adapters.
In fact sometimes 20mm ones can work also.
03-05-2007, 12:32 PM
Thanks for picture Jamiemirror! Smile
An '86 86 driver
03-05-2007, 12:42 PM
Thanx man! Smile
03-06-2007, 08:01 AM
Hey, guys keep this to yourselves, but one day jamie will conquer this world, i'm certain of it... no jokes.
[/offtopic]
03-06-2007, 10:35 AM
wtf ??? Evil
05-19-2009, 01:16 AM
jamiemirror Wrote:I have front wheel stud on my desk now.
Is this stock stud ?
10x
  Spare wheel & spare wheel carrier ondafly 6 598 01-19-2026 01:00 PM
Last Post: ondafly
  Quick question - Brake Pad Dimensions Lt86 2 6,493 06-07-2015 12:08 AM
Last Post: jondee86
  Dimensions clutch master cylinder bozu 2 7,460 04-16-2015 07:11 AM
Last Post: bozu
  Spindle dimensions, backing plate bolt pattern Rascal21 18 26,435 03-13-2014 11:45 AM
Last Post: Rascal21
  ARP Head studs in a N/A engine, necessary? Jimmi The Kid 13 18,188 02-04-2013 11:27 PM
Last Post: Jimmi The Kid
