Digital Dash
08-08-2014, 01:52 PM
Post: #151
Digital Dash
I'll be coming home again and will have time to play again with the digital cluster. hopefully I can make it work now. anyone has already made their own wirings and successfully worked?
thanks
08-08-2014, 03:49 PM
Post: #152
Digital Dash
Me Smile
08-08-2014, 08:03 PM
Post: #153
Digital Dash
Can you share your wiring? Smile Also, what test can I do to know if the IC for rpm is still working? Maybe I can borrow a signal generator if needed.
08-08-2014, 08:54 PM
Post: #154
Digital Dash
I have them somewhere.....
What i did was to use the original wires and added a bit more of wiring to "rewire" on the new dash!
Everthing is working so its done properly Big Grin
I'll take some pictures
08-09-2014, 05:17 AM
Post: #155
Digital Dash
(08-08-2014 08:54 PM)pack Wrote: [ -> ]I have them somewhere.....
thank you. my car is a KE70 race car, that is why I need the wiring diagram. I removed all the unnecessary wirings.
08-10-2014, 10:29 AM
Post: #156
Digital Dash
Is it possible to use an electronic speed sensor, then use it to the digital cluster? Anyone already did this?
08-10-2014, 02:31 PM
Post: #157
Digital Dash
Digital cluster uses cable, same as analog, have reed swtch which counts revs and translates to speed.
Not sure what kind of signal digital speed sensor makes, but i presume it is not switching current, guess it raises/lowers voltage as all other.
In that case one must make simple electronic circuit to get switching and wire it in place of reed switch.
Only thing left to solve is how to synchronize frequency of speed sensor with tacho display, i'm sure there will be significant difference.
08-10-2014, 04:36 PM (This post was last modified: 08-10-2014 04:41 PM by choyr.)
Post: #158
Digital Dash
i think it is hall effect, since it has 3 cables. my final drive now is 4.778 and when I use my speedo cable to analog cluster, it reads 30kph more.
08-11-2014, 08:24 AM
Post: #159
Digital Dash
I presume it was reading more even at 4.3 FD.
With 4.778 difference is 11% so it should read 30kmh more at 270 kmh Smile.
HALL or VR, doesn't make a difference, you will need some kind of circuit to adapt to AE86.
AFAIR there were some avaliable online, not cheap atlhough.
08-11-2014, 09:10 AM
Post: #160
Digital Dash
I would suggest putting an optocoupler in place of the reed switch, and feed that with the electric speed sensor signal. If the signal is too different and needs calibration, then you would need to put a microcontroller in there to read the signal and generate an appropriate output signal. Nice hobby project if you're into that sort of thing, it's very simple hardware wise, and I'm sure appropriate example code for the signal generation can be found online.
  Digital speedometer on stock dashboard FanIsHere 0 3,512 11-09-2022 01:36 PM
Last Post: FanIsHere
  Dash Waning Lights pack 7 8,369 10-06-2021 01:00 PM
Last Post: pack
  Trueno Digital dash kph to mph Bojack 3 10,162 11-21-2018 12:27 AM
Last Post: kazi
  Custom Dash Cluster kazi 14 29,392 10-24-2017 09:05 PM
Last Post: kazi
  Dash Lights kazi 3 8,104 09-12-2017 10:04 PM
Last Post: kazi
