Diferential Question
03-19-2009, 08:06 PM
I was sure you have it, all Corollas in Serbia are Switzerland or German imports and all are T283.
Rebuild kit is 150-200$ + work |
03-19-2009, 10:38 PM
About 99% of the EU spec hachis have LSD.
DJexor has one of the few exceptional cars with an open diff, but that was probably ordered that way.
03-20-2009, 12:04 AM
parrot Wrote:Chacaman, I think you are saying you have a 6.38 inch drum brake rear (S series diff)? If so, it is highly unlikely you will find an LSD for this. Tosco (TRD) did make them but a very long time ago and virtually unobtainable now. how i can see the version of my Diff ? if S or T ? |
03-20-2009, 10:14 PM
Honestly guys
before you start spending money ordering LSD and new bearings and so on. Pull your drive shaft out and measure it. Its the safest way. You dont want to order a LSD which cost you an arm or a leg. and find out that it only fits earlier or later model. AE86 is an old car, unless you are the first hand driver and know the full history of the car. Don't just order off the year of manufacturing. You never know what the pervious owner has done to the car. |
03-21-2009, 01:33 AM
panda_tureno86 Wrote:Honestly guys yes y true, a this point the Housing of dif have a Part no. or somenting for identified the Dif of the car ? |
03-21-2009, 07:30 PM
i have this:
Firewall: Model: AE86L-ESPXS Chasis: AE86-0134873 Color: 8A9-YQ82 Trans: A42DL Axle: S292 Toyota EPC: 02/1985 TOYOTA COROLLA (AE86L-ESPXS) SR GEN CP LHD 4A ATM 4FC 2D now i have a 4AG-Turbo Trans t-50 The Axle housing of the GTS and SR5 Have the same part number: ![]() i can change the: CARRIER ASSY, DIFFERENTIAL, REAR part number: 41110 from the GTS to the SR5 ? for example this it the img from LSD dif of GTS ![]() SR5 ![]() the external housing of the GTS and SR5 have the same part number. sow the Carrier assy of the GTS can fit on the Housing of the SR5 ? |
03-21-2009, 10:49 PM
Don't forget that this is only the first part of the partnumber and indicates the part name, not the part itself! So 41110 is the "CARRIER ASSY, DIFFERENTIAL, REAR" for all cars. I made that mistake a few times already!
The GTS axle has a 6.7 inch diff, so it will definitely not fit your SR5 axle. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
03-22-2009, 08:11 AM
Why not just get yourself a kouki disc break rear end?
it would save a lot of trouble. |
03-22-2009, 05:50 PM
It would only make it more work for him: besides having to replace the cables with brakelines he would need to change the brake valve and brake booster as well.
03-24-2009, 09:10 PM
But better for the long run !!
| How to remove diferential (from club4ag) | dreja | 4 | 7,348 |
02-04-2005 04:01 PM Last Post: NoHachi |
| Diferential (LSD) | s.bjelke | 6 | 9,603 |
11-12-2004 06:59 PM Last Post: Aico |
![AEU86 AE86 - Diferential Question [Image: AEU86 AE86 - Diferential Question]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Diferential Question [Image: AEU86 AE86 - Diferential Question]](http://www.toyodiy.com/parts/diag_AHEBzs.png)
![AEU86 AE86 - Diferential Question [Image: AEU86 AE86 - Diferential Question]](http://www.toyodiy.com/parts/diag_AI2PqJ.png)
![AEU86 AE86 - Diferential Question [Image: AEU86 AE86 - Diferential Question]](http://www.toyodiy.com/parts/diag_AI2PKZ.png)
