Diferential Question
03-19-2009, 08:06 PM
I was sure you have it, all Corollas in Serbia are Switzerland or German imports and all are T283.
Rebuild kit is 150-200$ + work
03-19-2009, 10:38 PM
About 99% of the EU spec hachis have LSD.
DJexor has one of the few exceptional cars with an open diff, but that was probably ordered that way. Wink
[Image: AEU86 AE86 - Diferential Question]
03-20-2009, 12:04 AM
parrot Wrote:Chacaman, I think you are saying you have a 6.38 inch drum brake rear (S series diff)? If so, it is highly unlikely you will find an LSD for this. Tosco (TRD) did make them but a very long time ago and virtually unobtainable now.
You will first need to upgrade to a T series rear end with the 6.7inch centre. LSD's for these are readily available.
how i can see the version of my Diff ?
if S or T ?
03-20-2009, 10:14 PM
Honestly guys
before you start spending money ordering LSD and new bearings and so on.
Pull your drive shaft out and measure it.
Its the safest way.
You dont want to order a LSD which cost you an arm or a leg.
and find out that it only fits earlier or later model.
AE86 is an old car, unless you are the first hand driver and know the full history of the car. Don't just order off the year of manufacturing.
You never know what the pervious owner has done to the car.
03-21-2009, 01:33 AM
panda_tureno86 Wrote:Honestly guys
Its the safest way.
yes y true, a this point the Housing of dif have a Part no. or somenting
for identified the Dif of the car ?
03-21-2009, 07:30 PM
i have this:
Firewall:
Model: AE86L-ESPXS
Chasis: AE86-0134873
Color: 8A9-YQ82
Trans: A42DL
Axle: S292
Toyota EPC: 02/1985 TOYOTA COROLLA (AE86L-ESPXS)
SR GEN CP LHD 4A ATM 4FC 2D
now i have a 4AG-Turbo Trans t-50
The Axle housing of the GTS and SR5 Have the same part number:
i can change the: CARRIER ASSY, DIFFERENTIAL, REAR part number: 41110 from the GTS to the SR5 ?
for example this it the img from LSD dif of GTS
SR5
the external housing of the GTS and SR5 have the same part number.
sow the Carrier assy of the GTS can fit on the Housing of the SR5 ?
03-21-2009, 10:49 PM
Don't forget that this is only the first part of the partnumber and indicates the part name, not the part itself! So 41110 is the "CARRIER ASSY, DIFFERENTIAL, REAR" for all cars. I made that mistake a few times already!
The GTS axle has a 6.7 inch diff, so it will definitely not fit your SR5 axle.
03-22-2009, 08:11 AM
Why not just get yourself a kouki disc break rear end?
it would save a lot of trouble.
03-22-2009, 05:50 PM
It would only make it more work for him: besides having to replace the cables with brakelines he would need to change the brake valve and brake booster as well.
03-24-2009, 09:10 PM
But better for the long run !!
  How to remove diferential (from club4ag) dreja 4 7,390 02-04-2005 04:01 PM
Last Post: NoHachi
  Diferential (LSD) s.bjelke 6 9,645 11-12-2004 06:59 PM
Last Post: Aico
