DIY: 4age Valve Stem Seals.
08-09-2007, 10:46 PM
Ivan141 Wrote:I get some smoke at startup, none visible when driving.. but it will leave small clouds when accelerating from a standstill full-throttle or on downshifts.
Oil pressure is not what it used to be either..
Sounds like you've got bad stem seals. Not too far off how mine was acting.
Oil pressure could be just the gauge/sensor changing resistance a little. Maybe try cleaning the contact to the pressure sender?
Andrew
10-18-2007, 07:49 AM
have changed the valve stems due to your help guys. jus wanted to say thanx Thumbs up!
http://www.heerlijklimburg.nl
11-12-2007, 12:58 PM
Does anyone know how to purchase this item? snap on sites only sell locally!
Best regards
11-19-2007, 06:30 AM
apardal Wrote:Does anyone know how to purchase this item? snap on sites only sell locally!
Best regards
Go to their website and see if they have your country listed, if they do it should lead to a website/portal for your country. Once their you can either purchase directly, or you can email them and find out WHO the local snapon 'agent' is to get a hold of them to purchase it.
Andrew
  4A-GE valve shim disintegrated DaLanZhu 2 2,222 04-30-2025 12:54 PM
Last Post: DaLanZhu
  4AGE Valve Buckets Scored Steller Engineering 2 2,347 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 3,494 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 4,043 05-25-2022 10:24 PM
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 22,814 12-21-2016 10:28 PM
Last Post: ditn
