DIV 1 rally/track suspension setup
04-05-2012, 10:12 PM
Post: #51
ditn Wrote:For anyone that is interested.
I had the suspension made with koni's in the back and bilsteins in the front
total costs was 1200€ for all four.
Tested on the circuit and it was Thumbs up! ,totally worth it and roald legal.
Thanks for the help everone
Respect!
Did you get B6 or B8 Bilsteins and are they valved as standard ?
cheers,
TC
04-05-2012, 10:34 PM
Post: #52
they are B8's and nothing internal is still original.
especially from the koni's.
I haven't tested it for rally yet but its a beast for track.
Tons of grip with street tires, i was really impressed.
NAd i didnt even have any bushing replaced then so it should be even better now.
04-06-2012, 12:06 AM
Post: #53
The B8's are still just an insert then ?
I have some B6's that are probably a long stroke version
of the 8's ?
04-06-2012, 08:48 AM
Post: #54
B8 have bigger internal bumpstops that reduce stroke but otherwise everything is identical.
04-06-2012, 09:49 AM
Post: #55
Ditn
Do you have part numbers / model of bilsteins / koni shocks.
Also can you make/buy more 4/3 springs?
04-06-2012, 09:56 PM
Post: #56
I can search for the model but i dont know how much you will have with that because nothing is original anymore.
I believe the koni's were the yellow ones everything replaced and the bilsteins came from porsche.
I will try to find it.
He can make any spring/shock combination so i can ask him that if you want it.
04-06-2012, 11:08 PM
Post: #57
Bilsteins are 99% certain the Porsche 924, golf, Jetta Bilsteins. Have partnumbers at home. They are available off the shelf in motorsport valvings. For the rear, the AE86 stock dampers from bilstein are really nice 46mm b6s.
04-10-2012, 12:32 PM
Post: #58
They must be from the Porsche 924 then Smile
I can't check the numbers right cause the car isnt at home but i will let you know
03-26-2013, 01:28 AM
Post: #59
http://www.rallyanarchy.com/EscortRallyPrep/
03-28-2013, 11:28 PM
Post: #60
thanks for the link got my suspension already but it is a good read Smile
Can always pick things up.
  Wide Track 86 Mylesmck 8 5,816 05-28-2023 09:51 PM
  wider rear axle,track width,suspension questions ditn 6 12,943 10-18-2016 11:50 AM
Last Post: fantapants
  4 Link setup and Traction brackets Jezza_hr 5 13,257 07-21-2014 09:12 PM
  Wheel adapters - track safe? El_Camino 19 23,632 02-04-2014 12:21 PM
Last Post: totta Crolla
  Fuel system setup 86Pilot 2 6,464 01-30-2013 04:24 PM
