DIV 1 rally/track 4AGE(objective +- 130 whp)
12-19-2011, 08:31 PM
totta Crolla Wrote:Please be careful when shaving heads. oldeskewltoy should be able to give a stock dimension off my virgin head (smallport though) AE86 ex-daily |
12-19-2011, 09:12 PM
PatrickAE86 Wrote:if you shave about 1mm the CR goes to 11:1 with oem gasket (1.2mm). With stock chamber (around 36cc) if you shave 0.8mm you loose 3cc (so -> ~33cc) If stock you have 10:1, after 0.8mm shaving -> ~10.8:1, + TRD 0.8mm -> ~11.1:1 Like I said, It will depend how far he will deshroud the combustion chamber. |
12-19-2011, 11:49 PM
Well the most important thing for now is to know what is inside the engine.
the 40/18 or 42/20. Any easy way to know this? ![]() Because the engine has 244000 km if it is still the original one. |
12-20-2011, 12:03 AM
My friend have 310000km on his AE86 and it's the original engine.
I don't see any problem with that :lol: The easy way... check the crankshaft. Maybe, if you have an endoscope, you can check via the oil drain plug but I'm absolutly not sure about that. |
12-20-2011, 04:24 AM
![]() Above is an approximate chamber volume, as based on how close the "squish area" comes to the intake valve edge. From my experience, if beginning with a head that has never been cut, you will likely have to cut the head about 1.2mm-1.5mm to get the chamber volume down to 33.25cc(+ or -) Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-20-2011, 09:24 AM
Ofcourse its important to know if its 40 or 42 mm! 40 mm would be the best choice if you want a revvy engine
7 rib + 40 mm + worked small port = WIN And you dont need to use expensive aftermarket parts for a build like this. My friend rallied an engine (as above) with 180 hp for years without any trouble - just need to be build right. Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch
12-20-2011, 10:44 AM
Project D Wrote:My friend have 310000km on his AE86 and it's the original engine. Mine car had 400 000+ km when i bought it, and was running strong... at least when AFM was working OK |
12-20-2011, 01:34 PM
Would the average guy at scrutiny know the difference between a 4a & a 7a?
Build a stock looking 7a An 86 is for Life, not just for Christmas |
12-20-2011, 01:42 PM
I will try to check this tonight.
So starting to tune with an 244000 km is no problem? The problem im facing right now is the following if i have the the 40/18 combination then i cant use the parts i want because those are with 20mm pins? 2)the shaving of the head im not to keen on,but i have no choice i guess? Jan Pedersen Wrote:Ofcourse its important to know if its 40 or 42 mm! 40 mm would be the best choice if you want a revvy engine sounds interesting,could you give more info on this if you want? ![]() @Eircamae86 yes they would,every person knows 4AGE and 7A apart +i want to stay 4A
12-20-2011, 05:17 PM
Probably but it really depends if they normally do it for every car.
However even if they don't know the difference, a competitor might protest and you'd have to open the engine and then they'll find out. Eircamae86 Wrote:Would the average guy at scrutiny know the difference between a 4a & a 7a? http://www.autoreverb.com - Loud automotive passion. |
| Wide Track 86 | Mylesmck | 8 | 4,883 |
05-28-2023 09:51 PM Last Post: Bean |
| wider rear axle,track width,suspension questions | ditn | 6 | 12,012 |
| Wheel adapters - track safe? | El_Camino | 19 | 22,192 |
02-04-2014 12:21 PM Last Post: totta Crolla |
| DIV 1 rally/track suspension setup | ditn | 60 | 87,749 |
03-28-2013 11:28 PM Last Post: ditn |
| track questions:max oil/water temp,egt and other | ditn | 7 | 10,047 |
07-06-2012 12:40 PM Last Post: ditn |
![AEU86 AE86 - DIV 1 rally/track 4AGE(obje...- 130 whp) [Image: AEU86 AE86 - DIV 1 rally/track 4AGE(obje...- 130 whp)]](http://i79.photobucket.com/albums/j143/oldeskewltoy/MOmo/comparisonchambersedge.jpg)
