07-28-2005, 03:32 PM
Post: #41
You got alot of work ahead of you, i hope it all ends up good and that you don't encounter to many problems along the way!
07-28-2005, 05:53 PM
Post: #42
WHOW! I'm not going to complain any more
![]() ![]() BTW what do you meen: Quote:4ag 20v black topp full conversion with gearbox and every thing. Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
07-28-2005, 10:47 PM
Post: #43
Hehe yes alot of work but we are making progress! new pics will be up later this night.
The work the previouse owner did is a disaster!!!! Jan pedersen what i mean is: AE111, 4AGE 20V Black top engine 5 speed gearbox, complete with all ancillaries to run, including, wiring loom & ecu, starter, alternator, coil & igniter and flywheel. specs: Another conversion we Import is the 4AGE 1600cc 20V (yes 5 valve per cylinder = TWENTY VALVE), Variable Cam Timing, 4 Throttle Bodies. Black top engine is rated at 165 ps @ 7400rpm in standard form with a cat this text is a copy (wich you all already noticed, alot better english then mine ![]() best regards |
07-29-2005, 12:42 AM
Post: #44
new pics, i am not done jet but i am on the way
07-29-2005, 01:01 AM
Post: #45
Are you planning on remaking your rear lights...?
![]() If not.. i do like that smooth look on the rear. Looking good thou! Keep it up! ![]() |
07-29-2005, 09:13 AM
Post: #46
this is just the begining it is not going to be this flat when i am done.
best regards daniel |
07-29-2005, 10:00 AM
Post: #47
Hey Daniel,
How are you going to treat the inside of the side seals? Now that you've cut away there you can clearly see its very rusty inside of them and thats something that you can't normally reach with sandblasting... Anyways, I'm amazed at the work your doing, keep those pictures coming, way cool work! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
07-29-2005, 10:37 AM
Post: #48
cp joel Wrote:Jan pedersen what i mean is:I know the engine... But you do know that the AE111 is FWD and AE86 is RWD, right? ![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
07-29-2005, 11:06 AM
Post: #49
the rear end is coing to be totaly rebuilt and designd more for drifftinf and my needs. rust eater is going to be used in these places.
ok sorry for not being clear enough, that gear box is from a ae86 with new bellhousing and flywheel etc. best regards daniel |
07-29-2005, 11:53 AM
Post: #50
Wow, either way you are an artist or an optimist - I would have given up that shell for dead, I dunno... Your list of parts also reads very impressive... keep the pics coming pls...
Later, Patrick |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 171,213 |
Lycan-Strife's Daily/Drifter 4agZe AE86 Levin Coupe | Okami | 21 | 28,694 |
01-23-2012 09:46 PM Last Post: banpei |
Ive been busy.. F20C AE86 (56k badness!) | PazzaAE86 | 46 | 92,776 |
06-25-2011 04:49 PM Last Post: kennedy8383 |
Old Fashioned | Apolan | 233 | 207,319 |
11-02-2010 07:02 PM Last Post: nmwisima |
Project: My new trackday toy (56k beware!) | Morten | 88 | 86,568 |
02-25-2010 01:44 PM Last Post: Morten |
