Clutch types for AE86
03-15-2007, 11:28 PM
there are of the shelf clutches that fit for the box and are 212mm dia. and i already have the ze flywheel on. is there any way of modifying the 1ggte bellhousing to fit a 4age engine, even if a little alu welding is needed?
Its gotta go whoosh or give a whine!!!!
03-16-2007, 11:07 AM
Maybe adapter plate between the bellhousing and T50 ?
Measure length of T50's (primary) shaft also with bellhousing "attached" to T50.
03-16-2007, 01:49 PM
"there are of the shelf clutches that fit for the box and are 212mm dia."
What clutch is that???
/Skassa
"""www.turbotoys.dk"""
03-18-2007, 07:03 PM
im not sure. when my brother did the swap, he went up to this place in Belfast that only do clutches and they had one 212mm on the correct splines. i may be confused though and they had 212 plates and changed the spline. ill ask him and find out, it would be so much easier if i was back home.
03-18-2007, 07:07 PM
Today's update:
Some Peugeot clutches use the same splines and are 230mm diameter. If someone uses custom fluwheel - they can fit (in fact I measured 212mm flywheel and there is enough place for 230mm work area).
The clutch used in this experiment was Peugeot 605 2.0 8V turbo one, the Peugeot owner said that Peugeot 405 T16 use the same.
04-24-2007, 08:52 PM
Got my clutch when i was home, he had to split 3 different kits to make one clutch, cost £60 which i cant really argue with cos the guy is always interested in the car rather enjoys making clutches rather than off the shelf. that included the pressure plate and release bearing.
clark bros in belfast.
07-09-2007, 03:37 PM
Does anybody know which brand is the AE92GTi factory clutch plate? This is the 212mm diameter, P/N 31250-17020 or 31250-12320 - no difference imho.
I thought it should be Aisin as many other parts and like the AE86 factory clutch but according to a dealer it isn't. I was told it is something like NKK or whatever...
Can somebody help me out with this please?
1987 Toyota Corolla GT coupe - for holidays oversteer
2005 Toyota Corolla - for daily understeer
11-18-2007, 09:52 PM
Could someone please advise if the aw11 clutch has the same splines as the ae86?
There is one on ebay that I might buy if I can use it.
Regards
Ian
11-19-2007, 12:21 PM
If it is for 4AGE engine - yes, same splines.
Avoid 4AGZE ones.
11-19-2007, 06:46 PM
Thanks for the reply Jamie..maybe I will bid on it now. Cool
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 6,525 07-25-2021 04:41 AM
  Anyone farmiliar with hks camshaft types for 4age? spill86 5 21,372 11-18-2017 11:36 PM
  Ae86 bulk head mod to fit hydrolic clutch? dinkers542 8 13,650 11-25-2014 09:21 PM
Last Post: dinkers542
  AE86 halfshaft types? TheGerman 6 15,341 11-27-2012 08:02 PM
Last Post: fax0815
  Exedy 'S New Metal' Racing Clutch Kit Toyota 4AGE AE86, dsrturbo 2 7,835 07-28-2011 10:51 AM
