Clutch rattling noise on deceleration
09-08-2025, 12:58 PM
Hello community,
Long time without any technical question but these cars.... oh my....
So, i've recently rebuilt a 20V to swap for my old one.
I've balanced the pulley, crank, and flywheel.
I've assembled the engine with OEM specs and OEM ECU.
Clutch is an exedy organic.
Status: When i decel, i can hear a rattle noise from the clutch at around 3k rpm... and i can feel a huge vibration in the entire car....
If i press the clutch pedal just slightly, it stops, if I go neutral, it stops...
So i know the noise is not from my differential, and i know it's coming from my clutch.
How can i get around this? Car is still drivable, but man... these vibrations and noises are killing me...
Thank you
09-15-2025, 12:03 PM
replying to myself here... Must be a spring or the clutch plate assembly that are not perfect.
Car is still driveable, and i'll remove my gearbox to check the plate.
11-04-2025, 12:57 PM
Bit late reply, but did you check you if your pilot bearing is still alive? Mine was broken once and i had the same experience
[Image: AEU86 AE86 - Clutch rattling noise on deceleration]
11-05-2025, 11:41 AM
Hey DJ,
My bearing is also new, came with the clutch.
Maybe if i take everything apart, i can have some sort of answers here...
11-05-2025, 04:27 PM
Even if its new it still can be faulty.
But how you describe it kinda sounds like it could also be the gearbox.
And don't forget to check the driveshaft!
Had a problem with my Miata where it sounded like it was the clutch bearing but after replacing that it wasn't fixed...
It ended up being the yoke of the driveshaft that had a hard spot when moving it side to side.
11-05-2025, 08:00 PM
Maybe the clutch fork?
11-06-2025, 09:39 AM
Clutch might have thrown a spring.. would be very weird for a new clutch to do that but I would not waste too much time and pull the gearbox off before you break something more expensive.
11-06-2025, 12:43 PM
I had my car running just fine with the Aisin..... Exedy noises after replacing it
  TRD Short Shifter Rattle Noise, It's Normal? Mattolo 19 25,037 04-27-2024 10:04 PM
  Clicking noise from glove box chrisae86 4 3,974 09-08-2022 11:36 PM
Last Post: chrisae86
  Noise Insulation for AE86 decryphe 1 5,223 11-03-2016 11:51 AM
  Whining noise HELP PLEASE izanagi 10 15,237 03-26-2015 06:48 PM
Last Post: Komba
  Whining noise only in 4th & 5th. izanagi 7 13,419 09-25-2014 07:09 PM
Last Post: Uzelac
