Cams for a stock 4age 16v
10-05-2008, 12:38 AM
Post: #41
I forget to note the injectors.
I know that the cams will notoffer all the power 100% with oem exhaust system and standard intake. But will be this moment very expensive if i ll set up an ITB and ll be necessary a standalone plus the exhaust system(really?).
I have find an ITB from Blacktop but i have to buy or made a adapter.
Thx a lot mate
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - Cams for a stock 4age 16v]
10-05-2008, 01:04 PM
Post: #42
What do you tell me about intake?
10-07-2008, 10:14 AM
Post: #43
what are the size for ae92 injector?currently im using it..anyway thanks for the tips robokill
10-07-2008, 01:17 PM
Post: #44
Don't the supra 7mge injectors (315 cc i think)do the job too ? :wink:
10-08-2008, 09:22 PM
Post: #45
Another vote for CATCAMS, I have just installed these:
http://www.catcams.be/800x600/prod01Adat...71051xx.js
with underbucket shims and I can already feel a lot more power all through the rev range, next stop the rolling road Smile
10-08-2008, 09:41 PM
Post: #46
which underbucket shims???
plz
10-08-2008, 10:38 PM
Post: #47
tolisspi Wrote:which underbucket shims???
plz
I'm sorry I can't confirm the Yaris ones for you as mine came from here:
http://www.arrowprecision.co.uk/details.php?id=66685 and then I had to sort out the little top hat shims, they sit like tiny upside down buckets on top of the valve stems.
Definately worth the effort in my opinion but I have not driven a car with similar cams with a lower lift.
I would also recommend fitting a lightweight flywheel.
I am still using the stock ECU and inlet etc. Idling is a little unpredictable but my intention is to fit some carbs I have in the garage.
10-08-2008, 10:45 PM
Post: #48
alimonos Wrote:Don't the supra 7mge injectors (315 cc i think)do the job too ? :wink:
Nope, those are WAY to big. Seen a 4age produce 190HP on 250CC injectors and still be able to run rich.
On shims matter you can always use Yaris/Vitz shims but you will need to measure.
10-08-2008, 10:57 PM
Post: #49
Yes measuring shims, the CATCAMS don't allow any tolerance 0.20mm is what they say. If I were to go the Yaris bucket route I would buy one bucket that was the smallest available and measure them all up from that.
You would need to take out and replace the cams 16 times though !
I have two A4 pages of calculations going from the stock buckets/shims to the tophat type I used and still some were out Banging head too thick so that was a bonus, I just ground a bit more off.
10-09-2008, 08:54 AM
Post: #50
Wasnt there someone who mentioned that 3SGE lifters will also work on a 4age (under-bucket shims!)?
  Digital speedometer on stock dashboard FanIsHere 0 2,546 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 4,416 11-24-2021 04:26 PM
Last Post: apardal
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 24,763 05-01-2021 10:09 PM
  4AGE 16V engine overheat when at high speed chenfon 32 32,477 12-31-2020 06:39 AM
Last Post: chenfon
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 10,414 11-09-2020 10:51 AM
Last Post: totta Crolla
