Cams for a stock 4age 16v
10-05-2008, 12:38 AM
Post: #41
I forget to note the injectors.
I know that the cams will notoffer all the power 100% with oem exhaust system and standard intake. But will be this moment very expensive if i ll set up an ITB and ll be necessary a standalone plus the exhaust system(really?). I have find an ITB from Blacktop but i have to buy or made a adapter. Thx a lot mate **COROLLA EE80 - 4AGE 124HP** ![]() |
10-05-2008, 01:04 PM
Post: #42
What do you tell me about intake?
10-07-2008, 10:14 AM
Post: #43
what are the size for ae92 injector?currently im using it..anyway thanks for the tips robokill
10-07-2008, 01:17 PM
Post: #44
Don't the supra 7mge injectors (315 cc i think)do the job too ? :wink:
AE86 FANATIC!!! |
10-08-2008, 09:22 PM
Post: #45
Another vote for CATCAMS, I have just installed these:
http://www.catcams.be/800x600/prod01Adat...71051xx.js with underbucket shims and I can already feel a lot more power all through the rev range, next stop the rolling road ![]() An analogue brain in a digital World |
10-08-2008, 09:41 PM
Post: #46
which underbucket shims???
plz **COROLLA EE80 - 4AGE 124HP** ![]() |
10-08-2008, 10:38 PM
Post: #47
tolisspi Wrote:which underbucket shims???I'm sorry I can't confirm the Yaris ones for you as mine came from here: http://www.arrowprecision.co.uk/details.php?id=66685 and then I had to sort out the little top hat shims, they sit like tiny upside down buckets on top of the valve stems. Definately worth the effort in my opinion but I have not driven a car with similar cams with a lower lift. I would also recommend fitting a lightweight flywheel. I am still using the stock ECU and inlet etc. Idling is a little unpredictable but my intention is to fit some carbs I have in the garage. An analogue brain in a digital World |
10-08-2008, 10:45 PM
Post: #48
alimonos Wrote:Don't the supra 7mge injectors (315 cc i think)do the job too ? :wink: Nope, those are WAY to big. Seen a 4age produce 190HP on 250CC injectors and still be able to run rich. On shims matter you can always use Yaris/Vitz shims but you will need to measure. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
10-08-2008, 10:57 PM
Post: #49
Yes measuring shims, the CATCAMS don't allow any tolerance 0.20mm is what they say. If I were to go the Yaris bucket route I would buy one bucket that was the smallest available and measure them all up from that.
You would need to take out and replace the cams 16 times though ! I have two A4 pages of calculations going from the stock buckets/shims to the tophat type I used and still some were out ![]() An analogue brain in a digital World |
10-09-2008, 08:54 AM
Post: #50
Wasnt there someone who mentioned that 3SGE lifters will also work on a 4age (under-bucket shims!)?
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,943 |
82mm Stock compression Pistons | apardal | 4 | 3,542 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 22,730 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 26,422 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 8,871 |
