Bushings!:)
04-19-2005, 09:08 PM
Bushings!:)
original bushing
[Image: AEU86 AE86 - Bushings!:)]
t3 delrin bushing
t3 delrin bushing in place
T3 camber plates
engine bay
camber! ok, this doesn´t show well....-1,7degrees (damn, with standard spring plates, it doesn´t allow more, the plate hit the chassis tower from inside Sad... )
t3 rca´s & prothane bushings
a job well done, now, i´m one official owner of a street kart
Did any of u notest the big increase in vibrations and noise after the poly bushings being installed?
04-19-2005, 11:32 PM
Bushings!:)
[quote="Tofu @ AE86"]
T3 camber plates
[Image: AEU86 AE86 - Bushings!:)][quote]
Tofu.....
when fitting the T3 CP´s... how did you do with the fact that the fron springs are way to large to fit the CP´s...
do you perhaps have any pics from below 6 with the entire front shock assembly laying beside the car ?
K
04-20-2005, 12:29 AM
Bushings!:)
err...no, i didn´t take any photos with the strut assembly out....but....does any body got the same problem?
because, i´m sure that with coilovers, that shouldn´t have any problem since the upper hat diameter is way smaller that the stock one... Huh
well....i need to investigate a little...
04-20-2005, 11:41 PM
Bushings!:)
Kristian, if you're not using coilovers it shouldn't be a problem because you just remove the top mount and leave the stock upper hat that receive the spring...
04-21-2005, 09:53 AM
Bushings!:)
2 tofu: you don't need RCA's when runing stock height. In fact you upset car's rollcenter. They are used to correct angle on lowered cars only.
04-21-2005, 10:34 AM
Bushings!:)
apardal Wrote:Kristian, if you're not using coilovers it shouldn't be a problem because you just remove the top mount and leave the stock upper hat that receive the spring...
thats the problem.
I´ll have totake the stock upper hat apart in ordet to fit it together with the CP.
strange, but true.
K
04-21-2005, 03:57 PM
Bushings!:)
errr...the car is lowered 30mm with sparco springs Tongue
04-21-2005, 04:34 PM
Bushings!:)
Tofu @ AE86 Wrote:errr...the car is lowered 30mm with sparco springs Tongue
Um....well then ok.
Stil rca's are most used on extremly lowered ae86. :wink:
Pitty you don't have coilovers yet.
06-06-2005, 02:21 PM
Bushings!:)
New problem with fitting bushings for rear swaybar !.
i just took the swaybar off the car.
but the new bushings are WAAAy to big - it says 22mm on the package.
but my swaybar is at the most 17-18mm
And it id NOT rusted on the fittingpoint
It will never fit
se picture.
have all you guys recived the same package as me ?
06-06-2005, 02:26 PM
Bushings!:)
KristianAE86, that is for the front. As far as i remember there are two types of front swaybars, one 21mm and one 22mm therefor double sets. What you want is this one;
  Poly vs OEM bushings Jezza_hr 5 10,719 05-14-2014 11:28 PM
Last Post: Jezza_hr
  Steering Rack bushings filh 4 8,309 03-12-2010 10:45 PM
Last Post: filh
  Drivers review Prothane Bushings Michel 11 22,687 04-13-2008 05:57 PM
Last Post: Mux213
  Witch one to buy?(Bushings) zounds 3 6,878 11-23-2006 12:03 AM
Last Post: delange
  Bushings question. CircuitFreak 18 24,256 06-20-2006 03:02 PM
