Built like an A-10 (Thunderbolt II aka Warthog)
06-02-2011, 02:48 AM
Petros AE86 Wrote:congrats mate..what mods you need to fit beams inside?you put it alone?what about ecu etc? Mods to the chassis? None. I was able to squeeze it in with custom engine/trans mount brackets and ZERO modifications to the chassis/engine crossmember/etc. Andrew |
06-02-2011, 03:18 AM
GOod stuff..
06-02-2011, 03:19 AM
Nice and quick work!
How is the ViPEC, looks good & does it costly? You have std internal of your motor? |
06-02-2011, 03:20 AM
06-02-2011, 04:41 AM
The Vi-PEC is around $1700 USD at this time IIRC. Motor is completely stock standard, except for the ITB's and manifold back exhaust.
Andrew |
06-02-2011, 08:10 AM
You know if they do a basic mapping for particular setup?
If dyno is not propular in my place. |
06-02-2011, 11:50 PM
I'm sure they can come up with a basemap.
Andrew |
06-06-2011, 08:29 PM
very cool setup! what bellhousing did you use for the swap?
06-14-2011, 06:19 AM
Nice job man.
Is that hp rating at the wheels or flywheel? |
06-15-2011, 07:16 AM
daytona350z - modified tarago/hiace bell.
Hachi Go - Thanks, that's at the wheel. Andrew |
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,573 |
| ae86 Trueno f20c Built to be driven not polished | Martynas | 45 | 64,254 |
05-29-2020 12:59 PM Last Post: decryphe |
| Racecar: TRD USA built ITA AE86 | oldeskewltoy | 38 | 51,609 |
07-22-2019 02:55 PM Last Post: apardal |
| ae86 3sge beams turbo built v mount intercooler | boryae86 | 9 | 25,530 |
10-25-2010 02:46 PM Last Post: boryae86 |
