Brake lights not working
03-07-2024, 11:24 AM
Hi guys
So my Trueno's rear brake lights are not working all of a sudden when I hit the brake pedal. I looked a little bit online and found out that it could maybe be the brake light switch at the pedal itself. I also was going to check if the bulbs went out but both going out at the same time does not make sense. What do you guys think? Do you guys have any images of how the pedal assembly are and where this switch is located? Thanks in advance! |
03-07-2024, 02:18 PM
Your brake light switch is located under the dash near the pivot bolt for the brake pedal.
03-07-2024, 03:42 PM
(03-07-2024 02:18 PM)Dave W Wrote: [ -> ]Your brake light switch is located under the dash near the pivot bolt for the brake pedal. Thanks for the help mate! I will check this out. Cheers |
| Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 16,772 |
| working out compression ratios | kazi | 2 | 5,856 |
07-16-2019 08:22 PM Last Post: oldeskewltoy |
| Dash lights not working. | kazi | 5 | 10,720 |
05-09-2017 12:31 PM Last Post: Ivan141 |
| Headlights - only high beam working | Jezza_hr | 3 | 10,189 |
01-10-2015 11:59 AM Last Post: jondee86 |
| Carina TA62 / TA60 heater blower stopped working | Bushido | 9 | 15,874 |
11-14-2014 12:57 AM Last Post: Bushido |
