Blacktop header?
04-14-2007, 03:51 PM
Blacktop header?
Hi, i've working on my blacktop project, but has a problem. The original ae86 header dosnt fit my blacktop engine, and the blacktop header will not fit because of the engine mount. What do you other guys with blacktop do? Modyfi the original ae86 header, or buy a new?(Were?)
04-14-2007, 04:00 PM
Blacktop header?
lhd or rhd?
04-14-2007, 04:04 PM
Blacktop header?
oldeskewltoy Wrote:lhd or rhd?Sorry, LHD!
04-14-2007, 06:42 PM
Blacktop header?
I believe everybody just slots the bolt holes on the ae86 manifold.. a bit of searching around the forum will probably find you some pictures.
04-14-2007, 07:22 PM
Blacktop header?
Ivan141 Wrote:I believe everybody just slots the bolt holes on the ae86 manifold.. a bit of searching around the forum will probably find you some pictures. Slots the bolt holes? There is a lot of space between the end of the manifold and the bolt hole! Ive been searching alot in the forum for some pics, but didnt found something! Also the diameter of the holes in the cylinderhead is alot bigger than the header from my stock engine..... :-( |
04-14-2007, 08:45 PM
Blacktop header?
Yep,
I have used the pld rwd manifold on my Blacktop, If you put it on its really easy to see, You just have to cut open the hole in each end!, then save the part you cut of, To use with a bigger washer, then it works. /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
04-15-2007, 04:32 PM
Blacktop header?
Oki thanks Skasssa. What about gasket, did you use the 20v one, or the 16v gasket?
| 20v 4age header | Alex170984 | 5 | 10,106 |
10-30-2013 12:53 AM Last Post: fax0815 |
| Exhaust Header 4AGE Mr2 Only | Alex170984 | 1 | 5,118 |
02-07-2013 01:36 PM Last Post: Alex170984 |
| Ashley competition header ? | Uzelac | 6 | 10,216 |
06-12-2012 01:42 PM Last Post: Uzelac |
| Header + exhaust for Beams setup | KD2229 | 8 | 16,592 |
10-03-2011 07:25 AM Last Post: KD2229 |
| New Toda 4-1 longtube header - 98000 yen | oldeskewltoy | 3 | 9,665 |
07-29-2011 08:54 PM Last Post: Bean |
