Banpei's two door panda Trueno from Japan
06-08-2026, 10:09 AM (This post was last modified: 06-08-2026 10:12 AM by Ivan141.)
Post: #141
What do you need connector wise? I have some assortment boxes and am willing to part with one or two connectors if it helps you out.
You can choose from:
AMP SuperSeal
Deutsch DTM
JST JWPF (very small form factor.. probably not what you need).
(*All are AliExpress chinesium copies, but they work okay)
All of them require specific crimping pliers so it would be best if I could crimp them for you too.
Perhaps if we meet up some time.
I am also relatively handy with depinning connectors and extending wires (I own a shitload of different crimps)
06-09-2026, 02:12 PM
Post: #142
Thanks for the offer, but no need for that: I have ordered the OEM ones now. I'm now keeping my fingers crossed they actually fit. Tongue
[Image: AEU86 AE86 - Banpei's two door panda Trueno from Japan]
06-10-2026, 07:50 AM
Post: #143
Where did you order them from? I got myself some (6pin) Yazaki connectors for my trueno taillights from Amazon JP (I think the shop is hi-1000EC).
06-10-2026, 09:53 AM (This post was last modified: 06-10-2026 09:53 AM by banpei.)
Post: #144
I ordered them via Mouser:
https://nl.mouser.com/ProductDetail/Yazaki/71232840
They only ship via FedEx, which makes it very expensive for just a few connectors.
06-15-2026, 09:13 PM (This post was last modified: 06-15-2026 09:44 PM by banpei.)
Post: #145
You may wonder why I am drilling a hole in my ashtray.
It's because I want to make an even bigger hole in it!
And why do I need an even bigger hole in my ashtray?
To hide the chime kill-switch! Tongue
The reason started with me pondering where to put the light switch for the foglights. There are a limited number of spots available on the dashboard of the AE86, and the GT Apex occupies 1 for the parking lights, 1 for the defroster, and 2 for the power windows, leaving a blank spot in case you need expansion for fog lights. I used the blank spot for the chime kill-switch:
My initial solutions were:
1. Print an adapter to change the coinbox (as seen in the picture above) into two spare blank switches
2. Cut a hole in the dash to the left or right of the present switches and add it there
3. Cut a hole in the side of the HVAC panel
I didn't want to spend another week on modelling and prototyping an insert for the coinbox, nor did I fancy making an irreversible change to the dashboard. So HVAC panel it was...
When I finally had the HVAC panel removed (which requires half the dashboard to be dismantled), I actually had a much better idea: why not install the switch to the back of the (unused) ashtray as a hidden switch?
With half the dashboard dismantled, it was much easier to install all the wiring. I was able to route all wiring neatly behind the dashboard panels and route the wiring towards the fog lights via the top of the right fender.
So now the fog light switch has been installed where the chime kill-switch once lived:
And how well does it work?
Thumbs up!
The sequence in the video is like this: the fog light covers open up when both the ignition key is in ACC, and the switch is turned on. When I turn off the switch, they will close. Then I enable the popups, turn on the fog lights and both are illuminated. Then I put the popups into maintenance setting (turning off the lights, but keeping them popped up) and then put the ignition key into OFF, which then turns off the fog lights, but the covers don't close. To close the covers, I first have to put the ignition key into ACC once more and then turn off the switch. And finally, I close the popups by moving the light switch into the off position.
In other news: tonight I went to have look at another garage box:
This box is lower than my current (2.2 meters versus 2.6 meters), but it's much deeper and wider (6 meters deep and 2.7 meters wide versus 5 meters deep and 2.4 meters wide). Even though this one is slightly bigger in volume, the actual reason for changing is very different: this garage box is only a 5-minute walk from my home, while my current one is 10 to 15 minutes by bike. I already made up my mind, and I'm moving into this garage in the near future. Hurray!
06-16-2026, 08:03 AM
Post: #146
Good find, that garage box.
Just FYI, I believe AE86.DDD has already modeled that coin box button insert at least 2 years ago and sells them.
06-16-2026, 12:01 PM
Post: #147
I completely forgot about AE86.DDD's coin box insert. Nevertheless, I like this option a lot better, as now the switch is hidden out of sight but still accessible.
06-16-2026, 10:26 PM
Post: #148
My old AE86 had a similar switch hidden under the dashboard to kill the expensive (at the time) alarm.
So when I saw that photo my first thought was: "Why are you showing everyone where your alarm kill switch is hidden?"
06-17-2026, 09:50 AM
Post: #149
(06-16-2026 10:26 PM)Power_uP Wrote:  My old AE86 had a similar switch hidden under the dashboard to kill the expensive (at the time) alarm.
LOL! Big Grin
Well, it is the perfect hiding place for an alarm switch. Especially if you have a couple of (fake) cigarette butts in the ashtray: nobody would dare to put their fingers in there! Cool
06-18-2026, 10:17 AM
Post: #150
Nice place for the kill switch Art and good that the garage is not lower than 2.2 with your length. Great find
  1985 Toyota Sprinter Trueno GT APEX kouki from Japan sheppardpat47 30 5,913 08-14-2026 10:16 PM
Last Post: jomme_mega
  Banpei's new TA60 family cruiser banpei 281 359,735 10-30-2024 11:48 PM
Last Post: DarkSupra
  My panda ae86 build Ellzbmx 10 22,843 06-03-2015 10:56 AM
Last Post: Ellzbmx
  JDMitch's 1983 Sprinter Trueno AE86 Panda JDMitch 24 44,429 09-01-2010 11:37 AM
Last Post: nunoturbo
  Re-painting my car [i need Panda 86 photos (high res plz)] daywalker 7 15,106 06-05-2010 02:55 PM
Last Post: jdm86gtz
