Banpei's two door panda Trueno from Japan
05-01-2026, 08:43 AM (This post was last modified: 05-01-2026 08:43 AM by banpei.)
Post: #111
Thanks! That's a good suggestion for the steel bracket and I'll use a rubber coating like plastidip. Thumbs up!
[Image: AEU86 AE86 - Banpei's two door panda Trueno from Japan]
05-01-2026, 02:55 PM
Post: #112
Nice work! I wouldn't be too afraid that this version won't hold.
Is this the correct EU-size battery? So you can fit an original bracket if you find one?
05-01-2026, 09:50 PM
Post: #113
Yes, this is the correct EU size battery, so an original bracket would work fine for me as well.
05-03-2026, 10:10 PM (This post was last modified: 05-03-2026 10:32 PM by banpei.)
Post: #114
Even though it was a rainy day, I went to a Cars and Coffee in one of the neighbouring towns. I took several photos, but forgot to take one of mine. The Trueno is obscured by the enormous Rolls in front of it:
The Trueno got a lot of attention today as a large portion of the crowd were driving MX5s and Nissan Micra K11s.
The Starlet is one of 4 original Starlets remaining that were used in the Starlet Cup driven on the Zandvoort circuit. The car is even on original B-registration, which means it used to be registered as a company van in the 1980s. Big Grin
The battery held up fine, and it was so nice to have an engine that fires up immediately! I don't remember the car ever firing up this instantly before. Hurray!
About the sticky rear brake issue: I think I found the issue. I did feel the wheels after the drive to the garage. The right-side rear one was warm (not hot), and the right-side front one was cold. I only drove about 10 kilometres in total, so that was much less than last time and last time they were really hot. (getting painful touching the wheels)
I usually drive to the garage, put the car in neutral and on the handbrake while I leave the engine running. Today, I deliberately didn't put the car on the handbrake before reversing into the garage and the rear brake wasn't stuck. So, the rear brake isn't the issue. My conclusion is that my rear bearings are most likely due for replacement.
05-03-2026, 11:58 PM
Post: #115
That Starlet is really nice, I feel like there aren't enough fans of the EP71. They're an excellent car and I even had one for a short time, but it seems that unless it's an EP91 turbo or a KP61 then nobody wants a Starlet anymore.
05-04-2026, 07:49 AM
Post: #116
Those starlets have their own little following over here. Plenty of them survived too, which also tells you something about the quality.
80% of the guys I share my garage with own one or had one in the past.
05-04-2026, 08:02 AM
Post: #117
Someone posted your car at this event in the "JDM Gespot" facebook group. I attached the pictures Smile
05-04-2026, 09:56 PM (This post was last modified: 05-04-2026 10:33 PM by banpei.)
Post: #118
Thank you very much for sharing those photos Koen! Thumbs up!
@Ivan I remember both The Doctor and D.Wars owning one in the past. If I remember correctly, one of them also swapped in a 3E engine or considered swapping in one.
05-06-2026, 11:45 AM (This post was last modified: 05-06-2026 11:45 AM by Ivan141.)
Post: #119
Half the garage is littered with little starlet engines and parts if you know what to look for. Thomas used to own one, Dennis still owns one, and a 3rd 'resident' who's not been on here keeps his 4EFTE swapped KP70 there during winter (and his son drives his ratty bonestock KP70). AFAIK, all I've seen them mess around with are 1E, 2E and 4E variants.
  1985 Toyota Sprinter Trueno GT APEX kouki from Japan sheppardpat47 15 2,259 03-19-2026 11:07 AM
Last Post: sheppardpat47
  Banpei's new TA60 family cruiser banpei 281 338,159 10-30-2024 11:48 PM
Last Post: DarkSupra
  My panda ae86 build Ellzbmx 10 21,655 06-03-2015 10:56 AM
Last Post: Ellzbmx
  JDMitch's 1983 Sprinter Trueno AE86 Panda JDMitch 24 42,384 09-01-2010 11:37 AM
Last Post: nunoturbo
  Re-painting my car [i need Panda 86 photos (high res plz)] daywalker 7 14,351 06-05-2010 02:55 PM
Last Post: jdm86gtz
