Back-Up (reverse) lights problem
12-27-2009, 05:06 PM
Hi guys,
My back-up/reverse lights not working anymore. My rear/turn/brake lights worked like normal. Where should I check? I think the back-up/reverse lights does not have apart fuse right? Or maybe the switch right under the car defect?
Thanks in advance.
12-27-2009, 08:08 PM
Check the connection between the rear light switch and the cable on the transmisson Wink It usually becomes loose Smile
12-27-2009, 08:13 PM
[Walaki]D`Lair Wrote:Check the connection between the rear light switch and the cable on the transmisson Wink It usually becomes loose Smile
the switch are under the car right?
12-27-2009, 10:18 PM
yes, on the left side of the tranny
12-27-2009, 10:20 PM
thanks
will check it
  Can you convert your 86 back too the original state? gh0st 7 6,770 04-25-2022 04:25 PM
Last Post: gh0st
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 16,392 12-19-2021 11:58 PM
Last Post: gh0st
  back camber of CBY roiz86 5 12,415 03-24-2013 02:00 PM
Last Post: roiz86
  4agZe problem solved - 99% IC problem Okami 41 51,363 07-12-2012 04:49 PM
Last Post: Okami
  Reverse gear selector wiring... 4000GT 5 10,068 08-28-2011 04:58 AM
Last Post: 4000GT
