Back Again; 3SGTE in AE86
12-07-2005, 11:28 AM
Post: #71
i have question about 3sge and w58 geabox.
i have chance to buy gearbox from supra mk3 (i hope its w58)how i can determine that? and another thing is 3sge engine that i have found in wrecked celica st18 turborolla: what i need to bolt these two things together? and what to runing this engine in ae86? will the kardan shaft fit the w58 without any modifications,and what about tranny mounts? http://www.86ers.org All the hachies that Daytona can only dream about. |
12-07-2005, 12:04 PM
Post: #72
Basically it is al custom work that you'll have to do..new motormounts, new trannymount or relocate current mounts, new oilpan, custom 3S to W bellhousing, prolly also a shortened prop-shaft, but you can probably source one from a different model that will fit...
It is a shitload of work, although some parts can be sourced from manufacturers. Rhett on the forums sells 3S conversion bellhousings and oilpans. I wouldn't bother with the work for an ordinary 3SGE...might as well drop in a high hp version or a turbo. A wheel to steer the front of the car A pedal to steer the rear |
12-09-2005, 09:24 PM
Post: #73
yes but i think NA is better for hachiroku, and i have w58 for little money the guy put 164hd gearbox in his supra and single turbo mgte with 480hp.
And the engine? i dont know what i choose but 3sge is good idea(i found wrecked celica st180), it has 178hp and with minor mods its possible to get 190-200hp from it. http://www.86ers.org All the hachies that Daytona can only dream about. |
12-10-2005, 05:59 PM
Post: #74
ST182 ? and they come with 2 gen 3sge producing a 156 ks (cat version)
st180 is 4afe powered (~ 105 ks engine). |
12-10-2005, 06:54 PM
Post: #75
thanks
i dont know the exact name only st18 the guy told me it has 178hp with chiped ecu cold air intake and sport exhaust whitout cat http://www.86ers.org All the hachies that Daytona can only dream about. |
12-10-2005, 11:25 PM
Post: #76
The 180hp versions of the 3sgte were mostly delivered in a mk2 MR2 package I think...If its the older version 3SGE it has no chance in hell of reaching those hp numbers with just bolt-ons...
12-11-2005, 01:37 AM
Post: #77
NH u got a leter surplus in your post btw.
12-12-2005, 08:31 AM
Post: #78
there is a "Beams" modification of 3SGE mostly from JDM Altezzas.
NA and ~200Hp in stock. that shows the potencial of this engine. btw, well known billzilla got this one in his hachi. |
12-12-2005, 01:30 PM
Post: #79
thanks i check it, but its not the beams version
12-12-2005, 02:45 PM
Post: #80
I wouldn't bother with the old celica version...The money involved with changing the engine to RWD setup is to much considering its relatively low hp output...200hp with minor mods is impossible..you are talking cams+standalone ecu to get to those levels.
you could try to build an opel 2.0 16v, but even those are expensive to convert to RWD..There is also the Alfa 2.0 twinspark..but those aren't that powerfull either. A wheel to steer the front of the car A pedal to steer the rear |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,871 |
| OST-045: 5AGTE... again ;) | oldeskewltoy | 16 | 16,743 |
03-27-2018 08:12 PM Last Post: oldeskewltoy |
| time to get her back on the road.. | worholm | 4 | 8,514 |
01-21-2017 09:33 AM Last Post: worholm |
| AE86 RESTAURACION FROM GUATEMALA SWAP 3SGTE updated Jan-2011 | CIVER | 44 | 81,610 |
03-09-2015 03:52 PM Last Post: RT |
| Ricks project AE85 (Back together with dyno results) | Rick | 132 | 263,266 |
07-05-2011 11:54 AM Last Post: Rick |
