Aram's 3SGE Beams Levin Coupe
11-25-2012, 02:37 PM
Post: #501
Right, some things I did:
I moved the side indicators into the citylight housing: ![]() ![]() And checking to see if it works: ![]() ![]() I broke of a plastic hosepipe, so that meant more work. I made a new one from aluminium: ![]() ![]() I was told the original AE86 reverse light sensor would fit in the Aisin 6 speed gearbox, but guess what, more work..... ![]() Almost all windows are in the car now, only the left rear side window needs to be placed, it was not to my liking the first time around. I also algined the doors and I wrapped the b pillar flat black: ![]() ![]() ![]() Front window is in, it has two seperate sides heated, it's a rallycar version.
11-25-2012, 02:46 PM
Post: #502
Ohh, and here is one window that got away......
![]() One of the last things to be done is the airbox, which is alot of work. I myself think a panel filter is always better than a mushroom one, so I asked a friend to build me one. These is what he came up with: ![]() ![]() ![]() ![]()
11-25-2012, 02:57 PM
Post: #503
Placing the maf sensor is pretty critical for a BEAMS, and getting a housing for the sensor is difficult aswell.
I finally got my hands on a original filter housing, and used parts of it for my own airbox. I wanted hear the engine running again so I hooked it up like this, but it wouldn't run stationary: ![]() Above a 1000 rpm though it ran like a dream ![]() But back to the box: ![]() ![]() And yesterday I had it welded up: ![]() ![]() ![]() Now it is back at my friends place to be finished, he will be making a labyrinth inside for better airflow and low turbulance at the maf sensor. |
11-25-2012, 09:05 PM
Post: #504
One more thing I did is reroute the loom on the engine.
It was not how I wanted it to run so I needed to change. Plus I used vulcanizing tape now, so it looks alot nicer too ![]() ![]() ![]() ![]() ![]() ![]() ![]() And an overal view as it is now:
11-25-2012, 09:52 PM
Post: #505
11-25-2012, 11:29 PM
Post: #506
Clean as F#CK!
11-26-2012, 02:51 AM
Post: #507
have you run the cables yet?
11-26-2012, 10:10 AM
Post: #508
About the airbox: does it offer easy access to the panel filter? I can imagine it being a pain to dissasemble the whole box from the car every time you need to change filters.
11-26-2012, 07:46 PM
Post: #509
McKenney,
Yes I have, still need to make pictures. ![]() Ivan, The top half of the box comes off like a regular airbox, so relative easy access.
12-21-2012, 08:19 PM
Post: #510
Right, the ecu needed a place to stay, but it was 1.5 times bigger than the 4age one.
A bracket was needed: ![]() ![]() ![]() The heater fits in it's original position, no pics yet of that, but I'm satisfied. ![]() I always disliked the lock on the feultank door, so I purchased a nice cable assembly from Mr McKenney. Now I can open the boot and tank door from the inside! ![]() ![]()
| ae86 racecar with beams engine | bakonick | 148 | 199,820 |
| Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 112,887 |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 19,875 |
| @dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 195,524 |
| AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 698,149 |
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0865.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0868.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0885.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0884.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0862.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0860.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0945.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0953.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0950.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0951.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0889.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0744.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0745.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0880.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0881.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0965.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0966.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0967.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0970.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0971.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0972.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0932.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0961.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0960.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0976.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0975.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0973.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0988.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0990.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0986.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG1004.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG1003.jpg)
