Aram's 3SGE Beams Levin Coupe
07-08-2011, 03:21 PM
Post: #311
Aram Wrote:
4.5AG Wrote:Hi ARAM,
any chance you can post a pic of the gear lever (j160 )
Cheers,
Vener
Which part mate, only the lever??
Yeah , I just want to see how far the lever of the 6 speed compared to the t50, did you have to cut a new hole?
Cheers
Vener
07-08-2011, 07:48 PM
Post: #312
Oh yeah, there has to be cut a new hole!
But I haven't done it yet because I'm trail fitting the engine combo in my old car, and I'm not going to cut that chassis. Wink
Soon as I have it installed in the new chassis I will post up pics here.
07-10-2011, 12:58 AM
Post: #313
Aram Wrote:Yeah, the stabi turned out really well. Smile
Philip,
I hope to see some updates soon! Smile
Please don't stress me :wink:
robo's on site and says you crazy/incredible. What do you think the rest of us think about you Tongue
you make me cut out a lot off things...
Philip
07-31-2011, 05:39 PM
Post: #314
Ok, had lots of work to do so not to much time for the toyo.
But i managed to finish the front subframe and do some work on the gearbox frame.
Before:
[Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]
And finished:
Gearbox frame before:
Now but still not finished:
07-31-2011, 06:06 PM
Post: #315
je maakt het weer veels te mooi allemaal,respect! Thumbs up!
drift ae86:308bhp/435nmEDIT:384pk/498nm!!!!>now DEATH)))
07-31-2011, 10:52 PM
Post: #316
zozo idd netjes zo.
ennuh die baksteun is ook mooi geworden Wave
08-03-2011, 04:02 PM
Post: #317
Aram,
Need your advise here, thanks in advance.
This is what I have done so far, still long way to go.[img name=]http://www.aeu86.org/files/ci/cimg0870_1_110.jpg[/img][img name=]ht
Finally, I have to remove the intake manifold to let it sit in this position.
So, what I want to ask now:
- Do I really need that 5mm spacer in the subframe, I think the position now is okay.
- I want to shave the end bit on the intake manifold to allow some more space, any concern on this one
Thanks for advise,
Yung
08-03-2011, 04:05 PM
Post: #318
Not sure why my post not following the photo.
Anyway, above is my progress so far.
I wish to have your advise here Aram.
I have finally remove the intake manifold to create some more space, and I want to shave some of the end bit off and reintstall it, any concern on this?
Do I need that 5mm spacer on the subframe, same as you do? I think the engine is now sitting quite --- Okay, I will remove the Beams Cover for closing the bonnet.
Please advise,
Yung
08-07-2011, 01:07 PM
Post: #319
Hi Yung,
It looks okay from here.
I have lhd car so I don't have a problem with the brake booster so I can't help you there.
I kept between 5 and 10mm space everywhere, I think that should be enough clearing.
On the subframe, I did need the 5mm lowering at least.
But I wanted to keep the cam covers so you need more space then.
Keep us updated! Smile
08-08-2011, 02:57 AM
Post: #320
Thanks for the reply.
For the brake booster, I will shave some of the intake mani off to create some space, let see how it turn out.
Also manage to locate the shift lever, that's in the front location now.
Will try to fabricate the Geear Box support bracket and finish the engine mount welding, hopefully this weel.
I am a bit of one-man team, so slow slow progress. Can only work on the car after work..... Thumbs up! d
  ae86 racecar with beams engine bakonick 148 195,646 04-23-2024 10:06 PM
Last Post: bakonick
  Krullibulls Ae86 BEAMS is the only way krullibull 86 109,729 05-07-2019 09:35 PM
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 19,249 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 190,845 03-28-2018 12:35 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 686,584 06-27-2017 12:21 PM
Last Post: DJexor
