Aram's 3SGE Beams Levin Coupe
07-03-2011, 03:18 PM
Post: #291
Ok, had a lot of delay here.
I ordered parts which were late or wrong. And I was busy with other stuff. Anyway, have done a few things though. Made a start with the bucket seat, but I had no idea it was going to be such a pita!! The ae86 is not really made for one I must conclude. I tried to make it work with a slide but it was way to high. Started out with reworking the Impreza frame, so I took it apart: ![]() But it was still too high in the end, so I ditched those. Then I cut off the side frames on the chair a bit and constructed a new frame for them: ![]() ![]() Welded and sandblasted: ![]() ![]() ![]() Had to remove some material from the side frame: ![]() Now it's fixed, but the height of the chair is now as high as the stadard chair... And this is just one side! Pffft...
07-03-2011, 03:32 PM
Post: #292
Had some plates lasered for the front subframe, I have lowered the subframe 5mm only, the engine mount plates are 5mm also.
![]() ![]() ![]() Now the engine has the perfect height I think: ![]() Then another big job, the gearbox subframe. I want it to look as something that came out of the factory in end, so I did it the hard way. I started with cutting up the original frame and reworking the parts I needed: ![]() ![]() Welded: ![]() ![]() And this for both sides. After that the middle part was to be made, so I started with a cardboard template: ![]() Then the real thing: ![]() ![]() ![]() And welded that up too: ![]() Now only the 4 corner parts need to be filled up. |
07-03-2011, 03:47 PM
Post: #293
So, Tuesday I was really happy because for the first time the engine and gearbox were hanging in their own frames for the first time.
![]() ....Unitl I looked at the next step, the steering rack. When I was test fitting it all fitted nicely, but meanwhile I had moved the engine back 8mm and it was sitting a bit lower and tilted aswell. Never stopped to see what it did for the rack. So now the oilpan was in the way, more specificly, a bolt of the oilpan. To make matters more complicated I noticed the MR2 steering rack was actually 20mm's longer than the AE86 one, so the quiafe quick rack was to short also, that is why I the steering angle looked off to the left. Luckily I noticed in time, and luckily it needed moving the steering rack, which gave me 10mm more room with engine. So I decided the relocate the rack mount on the subframe and rework the bolt on the oilpan. ![]() ![]() ![]() Now it fits! And I can start removing the webbing for the rack to fit properly under the engine. Then some new parts: A longer stabi, have not testfitted it yet: ![]() ![]() A new feultank lid without a lock: ![]() New feul pump holder:
07-03-2011, 04:54 PM
Post: #294
excellent m8
...as always
Philip |
07-03-2011, 07:26 PM
Post: #295
Thanks mate. :-)
How is your car doing?? |
07-04-2011, 03:00 AM
Post: #296
Great job mate.
A quick question for you. When you have lowered your Beams by 5mm, do you still need to modify the tunnel to fit the gear box. I believe you are using the 6s box. Thks, |
07-04-2011, 07:49 PM
Post: #297
Yes I am using the 6 sp, and the only modification to the tunnel is making a hole for the gear lever.
07-04-2011, 07:52 PM
Post: #298
I mounted the new stabi to see how it fits, and it looks great!
07-04-2011, 10:27 PM
Post: #299
OMG That stab is wicked!
07-05-2011, 08:19 PM
Post: #300
Aram Wrote:Thanks mate. :-) basically on a hold. Was in the garage on Sunday, but after seeing some of your ideas I ended up cutting out some metal :wink: ...I think I am stuck with a little longer ae86 break btw, that's a fat bar Philip |
| ae86 racecar with beams engine | bakonick | 148 | 197,474 |
| Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 111,164 |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 19,512 |
| @dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 193,020 |
| AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 692,346 |
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01258.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01336.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01338.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01356.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01361.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01363.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01366.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01265.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01264.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01268.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01271.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01259.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01261.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01263.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01262.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/01275.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5808.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5812.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5791.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5814.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5838.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5909.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5915.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5876.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5875.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5922.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5929.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMG_5926.jpg)
