Anti sway bar, What size?????
08-26-2009, 11:13 PM
I'm about to buy front an rear anti roll bar's an not sure what thickness to use?
The car is for track use only.
08-27-2009, 02:00 AM
take a good one for the front (like TRD or TANABE) and keep the OEM one at rear you'll get a beter tracktion Wink
SR Team
BURN THE RUBER NOT YOUR SOUL!
08-27-2009, 02:29 PM
So would the oem rear be better fo drifting?
08-27-2009, 05:05 PM
no, a stiffer one would be better. You can also try to put 2 OEM at the rear.
A cheap upgrade.
Look at ZaX ae86 thread(without sr20det)
Cheers
Philip
08-27-2009, 08:29 PM
you might look into the Whiteline adjustable rear sway bar... It allows some adjustment to "tune" the suspension
Dan -
  Bash bar for zenki trueno bumper gh0st 3 4,486 02-08-2023 10:50 PM
  What bar is it? FanIsHere 7 10,692 10-20-2018 12:14 PM
Last Post: FanIsHere
  Shim size for AM cams kazi 4 8,012 12-18-2017 05:34 PM
Last Post: oldeskewltoy
Wink Hub size kazi 5 12,850 06-09-2017 10:06 PM
Last Post: kazi
  Camshaft sprocket bolt size? harkes 1 6,433 07-03-2015 12:41 PM
Last Post: Dave W
