Anti sway bar, What size?????
08-26-2009, 11:13 PM
I'm about to buy front an rear anti roll bar's an not sure what thickness to use?
The car is for track use only. |
08-27-2009, 02:00 AM
take a good one for the front (like TRD or TANABE) and keep the OEM one at rear you'll get a beter tracktion
SR Team BURN THE RUBER NOT YOUR SOUL! |
08-27-2009, 02:29 PM
So would the oem rear be better fo drifting?
08-27-2009, 05:05 PM
no, a stiffer one would be better. You can also try to put 2 OEM at the rear.
A cheap upgrade. Look at ZaX ae86 thread(without sr20det) Cheers Philip |
08-27-2009, 08:29 PM
you might look into the Whiteline adjustable rear sway bar... It allows some adjustment to "tune" the suspension
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| Bash bar for zenki trueno bumper | gh0st | 3 | 4,381 |
02-08-2023 10:50 PM Last Post: Ivan141 |
| What bar is it? | FanIsHere | 7 | 10,551 |
10-20-2018 12:14 PM Last Post: FanIsHere |
| Shim size for AM cams | kazi | 4 | 7,878 |
| Hub size | kazi | 5 | 12,717 |
| Camshaft sprocket bolt size? | harkes | 1 | 6,381 |
