AE86 Rear Brake options.
03-07-2010, 02:16 AM
Post: #51
Hello ,
I think I've found my problem : I'm not using the correct caliper , despite it's from a Golf IV . I've noticed on your pics(NoHachi) that you have an external spring for the handbrake lever.
Mine has an internal system . That's not the trouble . The caliper sub-assy(support) is different from yours .
Got some pics :
I must find another caliper , but don't know what to look for , as it seems there are two models .
Will inquire next days .
Filh
Filh
Save the RWD cars
03-07-2010, 10:13 AM
Post: #52
yes its a different model. maybe search for audi a3 / a4. my set was from an a4 afaik.
03-10-2010, 12:30 AM
Post: #53
Got caliper support from I don't know Golf , Audi , as it was out of car.
Tried it , but now ,if I center the caliper support with disc , there is too much room to reach the stock ae86 bracket.
Do you have to put washer between bracket and caliper support ?
Or I guess I don't have the good caliper support again .
Really hard to find ...
Fil
Filh
Save the RWD cars
03-10-2010, 08:43 AM
Post: #54
yes i had to put washer (actually 2 of them for one screw) between the caliper support and the bracket.
see:
[Image: AEU86 AE86 - AE86 Rear Brake options.]
03-12-2010, 10:07 PM
Post: #55
Thanks for your reply . I think i'll go through . But it's race time for this week-end .
I just need some time .
Thanks for helping
Fil
Filh
Save the RWD cars
09-16-2010, 10:53 PM
Post: #56
Finally got them fixed . It took a long time but I had lot of other problems
(what else can you have with rallye cars?? Banging head Banging head )
Not a big difference with normal braking. But it was not the aim . It's not very useful to have lot of brakes on rear .
But it's an awsome upgrade for handbrake .
I had an Hydraulic system , but even with DS2500 Ferodo on rear , It's was not working each time I needed .
With the VW Golf , it's full time working .
The second advantage is the pads disponibility : VW is direct fit .
As rear ae86 Ferodo DS2500 doesn't exist , i had to cut other pads to give them the Corolla shape .
All my feedback is based on rallye use .
Phil
Filh
Save the RWD cars
09-17-2010, 08:22 AM
Post: #57
Good to hear its working for you filh and thanks for letting the rest of us know your experiences.
09-17-2010, 07:36 PM
Post: #58
I have stock Corolla E12 brakes at the rear, with Primera P11 discs....almost plug and play Smile Well...a hydraulic ebrake is a must after this conversion Wink
AE86 GT - SR20DET BlackTop //// Trackday beater
Citroen C4 Coupe VTR - 1.6HDi //// Streetcar
09-21-2010, 11:07 PM
Post: #59
Last rally ended with lot of damage : exhaust , starter , gearbox , and last but not least engine .....
But to speak about rear brakes , they survived the race .
This rally was very fast and good brakes were needed.
The Golf calipers are a good upgrade . They behave very well and I can feel a good difference with the stock Toyota.
But it was not my goal , I had them fitted to improve the handbrake action .
I already had an hydraulic one , but I was very unsatisfied with it .
Now it's very reliable and work almost each time I need it .
Just have a look at the 2 pics
Hope it helps
Phil
Filh
Save the RWD cars
02-28-2012, 10:56 PM
Post: #60
Did anybody find out wich Golf, model, year, engine ect. those calipers came from?
And can anybody tell me what the offset are on the Primera discs? I will try to find some other discs in same size, but with a center hub that fits. Its more easy to drill a new 4x114,3 pcd, than get an hub center ring.
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
Thumbs Up ITB filter options mister86 1 4,085 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 33,271 07-28-2019 08:17 PM
Last Post: harkes
  AE86 rear suspension options 2018 Alex 9 12,872 01-24-2018 02:25 PM
  Rear axle options Dino86 13 15,593 01-08-2018 10:19 PM
Last Post: ditn
  Gearbox and Diff options MIGGZFSU 35 33,316 03-26-2017 12:00 AM
Last Post: MIGGZFSU
