AE86 Rear Brake options.
03-07-2010, 02:16 AM
Post: #51
Hello ,
I think I've found my problem : I'm not using the correct caliper , despite it's from a Golf IV . I've noticed on your pics(NoHachi) that you have an external spring for the handbrake lever. Mine has an internal system . That's not the trouble . The caliper sub-assy(support) is different from yours . Got some pics : I must find another caliper , but don't know what to look for , as it seems there are two models . Will inquire next days . Filh Filh Save the RWD cars |
03-07-2010, 10:13 AM
Post: #52
yes its a different model. maybe search for audi a3 / a4. my set was from an a4 afaik.
03-10-2010, 12:30 AM
Post: #53
Got caliper support from I don't know Golf , Audi , as it was out of car.
Tried it , but now ,if I center the caliper support with disc , there is too much room to reach the stock ae86 bracket. Do you have to put washer between bracket and caliper support ? Or I guess I don't have the good caliper support again . Really hard to find ... Fil Filh Save the RWD cars |
03-10-2010, 08:43 AM
Post: #54
yes i had to put washer (actually 2 of them for one screw) between the caliper support and the bracket.
see:
03-12-2010, 10:07 PM
Post: #55
Thanks for your reply . I think i'll go through . But it's race time for this week-end .
I just need some time . Thanks for helping Fil Filh Save the RWD cars |
09-16-2010, 10:53 PM
Post: #56
Finally got them fixed . It took a long time but I had lot of other problems
(what else can you have with rallye cars?? )Not a big difference with normal braking. But it was not the aim . It's not very useful to have lot of brakes on rear . But it's an awsome upgrade for handbrake . I had an Hydraulic system , but even with DS2500 Ferodo on rear , It's was not working each time I needed . With the VW Golf , it's full time working . The second advantage is the pads disponibility : VW is direct fit . As rear ae86 Ferodo DS2500 doesn't exist , i had to cut other pads to give them the Corolla shape . All my feedback is based on rallye use . Phil Filh Save the RWD cars |
09-17-2010, 08:22 AM
Post: #57
Good to hear its working for you filh and thanks for letting the rest of us know your experiences.
09-17-2010, 07:36 PM
Post: #58
I have stock Corolla E12 brakes at the rear, with Primera P11 discs....almost plug and play
Well...a hydraulic ebrake is a must after this conversion
AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
09-21-2010, 11:07 PM
Post: #59
Last rally ended with lot of damage : exhaust , starter , gearbox , and last but not least engine .....
But to speak about rear brakes , they survived the race . This rally was very fast and good brakes were needed. The Golf calipers are a good upgrade . They behave very well and I can feel a good difference with the stock Toyota. But it was not my goal , I had them fitted to improve the handbrake action . I already had an hydraulic one , but I was very unsatisfied with it . Now it's very reliable and work almost each time I need it . Just have a look at the 2 pics Hope it helps Phil Filh Save the RWD cars |
02-28-2012, 10:56 PM
Post: #60
Did anybody find out wich Golf, model, year, engine ect. those calipers came from?
And can anybody tell me what the offset are on the Primera discs? I will try to find some other discs in same size, but with a center hub that fits. Its more easy to drill a new 4x114,3 pcd, than get an hub center ring. Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
| Bigger brake master cylinder options | Koen | 10 | 3,642 |
01-08-2026 03:12 PM Last Post: r.ave |
| ITB filter options | mister86 | 1 | 5,529 |
12-06-2020 10:44 AM Last Post: Bean |
| AE86 starter options | max_ae86 | 12 | 38,900 |
07-28-2019 08:17 PM Last Post: harkes |
| AE86 rear suspension options 2018 | Alex | 9 | 16,497 |
01-24-2018 02:25 PM Last Post: mad.matt |
| Rear axle options | Dino86 | 13 | 20,617 |
