AE86 N2 (big update)
08-03-2008, 08:37 AM
Post: #51
Very good project!!!
Which lights/lambs (blue) do use to the cluster?
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - AE86 N2 (big update)]
08-03-2008, 08:52 AM
Post: #52
It's just some simple leds you can easily find on ebay.
You just have to take off the OEM bulbs and simply replace them with the leds.
These ones are supposedly "bright white".
86'LEVIN Track Project
08-04-2008, 09:59 AM
Post: #53
how hard/easy is it to replace the OEM bulbs in that case? (and does the dimmer still work?)
I think I've seen those LED replacement bulbs on ebay too. Makes the cluster look pretty good anyways Big Grin
08-04-2008, 02:15 PM
Post: #54
You can do the job in about 15minutes. It's easy and simple.
The dimmer won't work after the replacement, because you're using leds. If you rotate the dimmer it will only change from lit to completely off.
01-14-2009, 06:19 AM
Post: #55
A little update:
A "diy" shortshift Cool
The aluminum plate was fabricated (similar to the one provided by T3) with a 20mm thickness
[Image: AEU86 AE86 - AE86 N2 (big update)] [Image: AEU86 AE86 - AE86 N2 (big update)]
Cleaning up
The car awaits the upgraded organ...
Cutting...
A 20mm metal cylinder was welded in between
Greasing up...
Paper gaskets
Final assembly
Done!
A good and inexpensive upgrade. It doesn't make a big difference in performance but the gear changes are quicker and smother.
The next step is to get a taller gear shifter to have it closer to the steering wheel.
And more recently, I finally got some time in Portugal to mount the trailing arms and panhard rod. Smile
Panhard rod ends
OEM vs upgraded Cool
A kind of a hassle to take some of them out of the mountings!
Panhard and traction bracket installed
A bit of "tender" hammering was required in order to put those new rod ends into place
And the four link finally installed and ready for its first play:
After a quick spin, I should say that there is a big difference in handling and in the overall driving feel. The car feels so much more direct and the reactions of the rear axle are immediately converted in steering feedback.
A really good investment. Thumbs up!
I didn't have the time to adjust the lenghts of the trailing arms or at least the panhard in order to recenter the rear axle but at least the non-existence of bushing compliance in the rod ends really makes a big difference.
Regards from icy Oxford
Wave
01-17-2009, 01:09 AM
Post: #56
Very nice! :wink:
Sideways? Just for fun... not a way of life.
01-17-2009, 02:07 AM
Post: #57
86Pilot Wrote:A little update:
You have to test drive my car, 25mm will deff change your mind Tongue
Awesome project has always Luis Respect!
01-18-2009, 09:57 AM
Post: #58
Nice stuff, mate! What make is that four link kit + panhard? It looks very nice Thumbs up!
01-19-2009, 02:13 AM
Post: #59
Jan, its a TCS kit. Bought it on ebay from the states.
A lot cheaper than Cusco or similar brands and its with pillowball joints like I wanted. :wink:
01-19-2009, 02:20 AM
Post: #60
hey Luis your levin is getting better all the time Thumbs up! good stuff
  OST-125: Building a big valve 5AGTTE (yes, twin turbocharged) oldeskewltoy 3 121 10-07-2026 05:20 PM
Last Post: oldeskewltoy
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 6,589 09-09-2022 09:07 PM
Last Post: Vaptor
  American Rally 86 UPDATE dazed_driver 135 203,722 03-28-2012 12:53 AM
Last Post: dazed_driver
  86er's Track rebuild N2.??? Finally an update page 8 86er 191 320,774 03-25-2012 10:05 AM
Last Post: bozu
  Supercharged Hachiroku "update" roadrunner 20 32,508 06-02-2011 03:27 AM
Last Post: kennedy8383
