AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides
12-05-2008, 07:22 PM
Post: #101
Conrad Wrote:Lew, I'll see how low it sits once its mounted in, if its a problem I'll either get an aftermarket one or get a custom one fabbed up. You got PM
Ex-owner of JDM 83' Trueno Coupe DCw Classic, classic cars restoration, JDM wheels & parts import, sales. http://www.facebook.com/DogCustomWorks +37067170000 |
12-06-2008, 04:15 AM
Post: #102
Some nice bits there, liking the Tilton set up a LOT!! ... Looking forward to seeing it assembled & the rest of the brake components too
Are RS going to be extending the gearbox housing to make it flat further back? I could imagine it maybe difficult to seal it from noises & smell with a rubber gaiter otherwise.. An idea: As you have a deep dished wheel which presumably you'll use with a long boss kit - and the gear shift comes out further aft, maybe it would be a good idea to mount the pedal box and seat rail(s) further back too. Could help with weight distribution too, perhaps? Loadsa space there to make a nice intricate equal length 4-1 manifold...! Loving how this car's progressing! VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
12-06-2008, 03:35 PM
Post: #103
Hopefully RS are extending the tunnel for the new setup.
By nature of where the Tiltons sit they are actually further forward than the oem pedal set so I think by the time the deep dish wheel and boss kit are on it should be ok. I will need to see how far back the seats actually go before we decide to move the rails. I have my eye on a nice manifold already
I'm currently taking HRT ~ Hachi Roku Therapy |
12-11-2008, 11:40 PM
Post: #104
First up, the cross member recieves a little extra bracing as the sump doesnt interfere like the S2000 engine would have. Some new steering rack brackets have been fabbed up as well to cater for the new non ps rack.
![]() ![]() ![]() ![]() Further mods to the cross member as the angle of the engine mounts are different to the original 4AG engine resulting in finished mounts for the Beams engine. ![]() ![]() All bolted up to the cross member and ready to go in the car... ![]() In it goes complete with the crossmember spacers to lower it. I appreciate that the steering rack and arms will be lower and this is caterd for later. ![]() ![]() ![]() ![]() ![]() With the engine mounts finished its time to go to the back of the car and cut the floor out to make room for the rear fuel cell, battery compartment etc. ![]()
12-11-2008, 11:52 PM
Post: #105
Super project man
I thought about going the same way with my Hatchi, but ended up going F/I route... just need more Torque But the fabrication amount / qulity - looks super
12-12-2008, 06:08 AM
Post: #106
hi conrad are you still after parts before xmas or next year for inlets quad throttles or are you going down another road glenn
12-12-2008, 11:41 AM
Post: #107
Hey Glenn, no still as planned, will be intouch shortly
01-07-2009, 12:57 AM
Post: #108
have you recieved the quad set up yet
glenn |
01-07-2009, 10:46 PM
Post: #109
Glenn, recieved thanks,
Not much happening at the fabricators.... Heres the latest revised spec.... 1987 AE86 GTV Multipoint cage BEAMS engine consisting of Forged Pistons, Forged Rods, Uprated long duration and High Lift Cams, TODA adjustable cam pullies, Uprated Valve Springs, TRD Sump & Oil Pickup Modifications, TRD lightweight Flywheel, TRD uprated clutch, TRD clutch cover, Race spec bearings, all balanced and built up to race spec by an F1 engine builder. BEAMS 6 speed box. TRD exhaust manifold. Custom exhaust system. Individual 50mm Throttle bodies. New Aluminium Radiator. Digital Dash with CAN communications to the ECU. 15" RS Watanabe Wheels. TOYO R888 tyres. Shell seam welded & strengthend around the front end / turrets. Run Free Type II bodykit - front Bumper, side skirts & rear bumper. J-Blood Carbon bonnet with central vent. Crystal Body Yokahama Lightweight FRP tailgate & catches. BRIDE Zeta III bucket seats. KEY!S 3 spoke deep dish steering wheel. TRD Horn button ![]() AP 4 Pot Calipers, Discs & bells up front. AP 2 Pot Calipers, Discs & bells at the rear. OEM rear calipers for the handbrake. Driftworks Upright Hydraulic Handbrake assembly. TRD F & R Antiroll bars. TRD Inserts for the coilovers. Swift Front Springs. TRD Rear Springs. T3 Adjustable camber plates. T3 bottom arms. T3 Traction control arms. Non PS steering rack. Red Line rear lights. Plexi glass all round apart from the screen. Rear Enclosed Fuel Cell assembly, Aeromotive fuel pump, billet fuel filters. Maybe.... Carbon Doors Decision on the ECU..... I'm currently taking HRT ~ Hachi Roku Therapy |
01-23-2009, 09:45 PM
Post: #110
Big update from the fabricators. Modified rear end is well on its way and the mock up of the front end is also underway. Oh and the driver, passenger footwells have been cut away and replaced with flat plate.
Heres a few pics of the progress. Enjoy...... Rear end mods for the enclosed fuel cell and battery housing. ![]() ![]() ![]() The finished item will have a lid on it that bolts down. ![]() Mockup of the front end...lots more to come! ![]() Note: Inner arches will be replaced. ![]() ![]() New drivers side footwell, ready for the Tilton pedal set ![]() New passenger side footwell to match. ![]() A few more next week as a few TRD goodies have arrived for the Beams engine [/img] I'm currently taking HRT ~ Hachi Roku Therapy |
| ae86 racecar with beams engine | bakonick | 148 | 197,171 |
| Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 110,845 |
| Aram's 3SGE Beams Levin Coupe | robokill | 665 | 854,291 |
| Beams Levin build | mannix20vt | 5 | 11,344 |
| Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 101,747 |
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4534.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4532.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4531.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4538.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4539.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4540.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4541.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4542.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4545.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4546.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4547.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4549.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4758.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4759.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4757.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4764.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4761.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4762.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4763.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4756.jpg)
![AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides [Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]](http://i251.photobucket.com/albums/gg299/Conrad_Bradley/AE86/CIMG4760.jpg)
