4age rally cams
09-15-2011, 08:32 PM
4age rally cams
hi guys;
i have come across 2 rally camshafts for a 4age 16v engine that i got from a mate years ago he had tried them in his rally ae86 but could not get the engine to run right on them the cams have no part numbers stamped on them but the the have 8.5 gpa stamped on the rear face of each cam i take it that this refers to lift what is the best way to work out duration i am currenty rebuilding a silver over graphite uk car with 72.000 miles for the road and planning on using a martelus R1 4 branch and system is it possible to run these cams with std engine with some head work/porting and polished thanks john |
09-15-2011, 09:06 PM
4age rally cams
Lift's not big problem, duration can be. Everything above 264 is hard to run on stock ECU.
Beside, every modification will make difference between what engine needs and what stock ECU commands. So.... depends what you want from engine, if you push it to hard, you will need standalone ECU (great and expensive) or piggyback (not so great, similary expensive). Duration can be measured, but you can visually compare them to similar, you will get idea if they are low, medium or high duration cams. |
09-15-2011, 09:16 PM
4age rally cams
thanks uzelac have u any pictures of cam angles so that i can compare
will 8.5 lift be ok with std head john |
09-15-2011, 09:55 PM
4age rally cams
8.5mm is fine with standard head, you can get 264's with this amount of lift.
1985 Sprinter Trueno GT Apex 2013 GT86 Miltek Exhaust, Injen Induction. |
09-15-2011, 09:59 PM
| 4age rally cams | |||
09-15-2011, 11:24 PM
4age rally cams
8.5 works on standard head, but NOT standard valve springs! You will need to upgrade valve springs if the lift is over 8.2mm
Here are some end views of camshafts, with the durations labeled under them.
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-21-2011, 11:08 PM
4age rally cams
thanks for the advice
dan any ideas on cost and poundage of springs that i would need is std springs 16kg john |
09-22-2011, 05:24 AM
4age rally cams
gtjohn Wrote:thanks for the advice I used TRD springs (90501-AE851)... 54#s @ the seat, and 144#s @ .400 lift Toda springs are good to 10mm of lift, and I'm not sure about HKS springs. I do not know the #s of the Toda, or the HKS springs Did a few minutes research and for some reason everyone wants a set of testicles(over $500 per set) for the TRD springs. The TODA springs sell for about $170 for the set. HKS are similarly priced to the Toda springs Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-22-2011, 08:36 AM
4age rally cams
hKS should be good for the lift, as same as their cams - don't know about force. You can ask here http://www.perfectrun.jp for prices.
AE86 ex-daily |
| Shim size for AM cams | kazi | 4 | 7,825 |
| Toda Cams | Alex170984 | 7 | 12,044 |
02-11-2017 05:50 PM Last Post: Alex170984 |
| 20V cams - CATCAMS vs KELFORD? | Grant | 19 | 47,152 |
11-19-2015 07:45 AM Last Post: hachirokkos |
| cams cams cams | megabob | 60 | 76,047 |
12-31-2013 01:19 AM Last Post: gze spec |
| part numbers on standard cams | Alex170984 | 10 | 16,044 |
09-19-2013 02:53 PM Last Post: pack |
