4age oil pan + cooler to a 4AGZE ?
09-07-2011, 10:27 PM
Hey die hard tech nutz Tongue
I need help on this as I couldn't find anything at all on the interwebz...
I have a GZE in my AE right now and I need to grab the bottom oil-pan (Carterpan) and put it on the GZE
But how does it work and where do I fit the oil cooler?
Does the oil-pan need a new gasket?
Please help me out - all help is welcome - thanks in advance again guys!
-DWG- Drift Wolf Gaming
09-07-2011, 10:34 PM
I do believe I used liquid gasket on oil pans in the past...shouldnt be a problem (it needs a gasket!).
Oil cooler goes between the sandwich plate under the oil filter and the return pipe on the oilpan. If you cant find them, chances are you dont have them or need to transfer them from your old engine.
09-07-2011, 10:52 PM
Thanks Ivan
If more people wanna brush up on this you're more than welcome.
Pics might also be nice if people have done this in real life Tongue
Thanks
09-08-2011, 08:24 AM
hey mate,
in my case it was like ivan said, i had to use the oilpan and sandwichplate from 4AGE to fit it my GZE, everything is plug an play.
greets
09-08-2011, 10:20 AM
swap oilpan and sandwichplate with new gasket and o-ring
and connect your cooler on it Smile
'87 levin coupé
[Image: AEU86 AE86 - 4age oil pan + cooler to a 4AGZE ?]
09-08-2011, 02:56 PM
I would take an aftermarket sandwich plate with thermostat and a new oil cooler. The original setup is not very effective so a full flow setup would be a great improvement Thumbs up!
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 65,939 11-18-2022 02:19 PM
Last Post: FanIsHere
  Oil cooler totta Crolla 0 2,282 07-25-2021 03:25 PM
Last Post: totta Crolla
  Oil cooler kit izanagi 7 10,449 09-20-2016 11:13 AM
Last Post: harkes
  Oil Pan Issue Alex170984 6 8,462 01-11-2016 04:50 PM
Last Post: Alex170984
  Permanent oil cooler vs thermostat Lt86 19 24,874 03-28-2015 06:54 PM
Last Post: Lt86
