4AGE MEGASQUIRT BASE MAP NEEDED
07-11-2008, 09:35 PM
Hi i'm just after installing MS1 with a pc3.57, i'm using the orignal distrubutor an i've 20v itb's, high lift cams etc., just want a base map to see if i can figure it out before i bring in to the dyno.
Checked on MSi an a couple of other sites but i can' find anything |
07-12-2008, 12:26 AM
o have one but it is with the high resolution code and using hybrid alpha-n.
let know ..... PS : you would have to calibrate the tps exactly as mine , or change the values on the tables ... |
07-12-2008, 11:31 PM
Yeah thanks anything at all, i've nothing set
07-13-2008, 01:15 AM
map sent
keep in mind that i was using 315cc injectors and alpha-n so check fuel and spark tables tps values , and change them accordingly to your tps values |
07-13-2008, 12:22 PM
tanx qon, yeah looks good, did you use your orignal distributor?
07-13-2008, 05:16 PM
yup .... with an MAF ignitor to convert the signal from the dist to the MS
07-13-2008, 09:19 PM
Go ask on the other sites, there are a lot of guys that have the base maps available.
07-14-2008, 06:42 PM
MAF ignitor ? what way did you do that?
07-15-2008, 12:39 AM
the MAF ignitor has a built in signal converter (from analog to digital) so I used that one instead of using the LM1815 on MS v2.2 or the built in converter on the v3 board.
Since it was design by toyota it might do a better job, and I have the v2.2 board , so it's a great help to have the signal already in digital. |
07-15-2008, 08:28 AM
ok thanks alot qon
| map sensor cheating? | fdsjakl890 | 8 | 1,805 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| AFM to Map Conversion | ps13michi | 3 | 5,060 |
| Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 15,114 |
| extracted freedom ecu 16v ignition map | ditn | 7 | 10,930 |
| smallport question AFM or MAP? | fax0815 | 5 | 9,709 |
05-17-2014 05:07 AM Last Post: jondee86 |
