4AGE 16V engine overheat when at high speed
11-07-2020, 10:29 PM
Post: #31
Ugh! That looks gross! Huh
Great to hear you found it! Thumbs up!
[Image: AEU86 AE86 - 4AGE 16V engine overheat wh...high speed]
11-14-2020, 10:41 PM
Post: #32
How did you dismantle the radiator and then put it back together again?
12-31-2020, 06:39 AM
Post: #33
(11-14-2020 10:41 PM)decryphe Wrote:  How did you dismantle the radiator and then put it back together again?
My apologies for late reply.
I bought a small size "utility Plier" and do small modification at tip area with angle grinder.
The front end grinded as below photo
This piers is to dismantle the radiator cover.
To put it back just use a standard "adjustable locking plier"
Tq
  Blacktop 20V high idle Bravothreezero 3 705 08-28-2026 01:11 PM
Last Post: jdm86gtz
  High-beam warning lamp Mylesmck 4 4,598 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 6,125 08-30-2022 07:11 PM
Last Post: Power_uP
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 27,088 05-01-2021 10:09 PM
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 12,180 11-09-2020 10:51 AM
Last Post: totta Crolla
