4A-GE engine mix - question
03-07-2012, 12:36 PM
Post: #71
Don't know that. Can't find info online, and by the looks... they are pretty thin. Not sure how much material thickness is needed to be safe.
03-08-2012, 04:13 AM
Post: #72
you could contact Wiseco, tell them your piston part numbers, explain you need to lower compression because your head chambers are too small, and that you want to machine down the crown of the wisecos, and you need them to tell you how much can be cut down.
Dan -
03-08-2012, 12:35 PM
Post: #73
oldeskewltoy Wrote:you could contact Wiseco, tell them your piston part numbers, explain you need to lower compression because your head chambers are too small, and that you want to machine down the crown of the wisecos, and you need them to tell you how much can be cut down.
as above, this will bring you the most benefit from all options. if that doesn't work your last reasonable resort would be a HKS headgasket, should be around 100€ incl. postage etc and they are available in 1.6 and 2mm but you'll be decreasing the efficiency of the squish area.
AE86 ex-daily
03-08-2012, 01:01 PM
Post: #74
Good info, at last Smile
Machinist cut a head a little deeper, around .5mm whole chamber, not sure.
ATM cc is 33.8, looking good Smile.
Valve seats are going by .1-2mm more, maybe they will slightly touched.
That should bring cc at 34cc which will bring CT to exactly 12:1.
  Question about 4AG 20v Engine Block CHACAMAN 1 3,339 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 16,366 04-19-2021 10:08 PM
Last Post: Hanzo
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 10,808 10-30-2013 11:18 PM
  RE: mix and match the 4AGE.. panda_tureno86 4 6,726 01-18-2012 08:20 PM
Last Post: panda_tureno86
  Engine question. caper 24 29,489 07-25-2010 07:04 PM
Last Post: caper
